Check Engine Light and Triangle; Car is acting weird
Discussion in 'Gen 2 Prius Main Forum' started by Rebecca Leyva, Apr 3, 2017.
  1. bisco
    52,927
    to get some understanding of rebuilding the hybrid battery, see the thread in the gen 2 prius technical discussion forum titled 'gen II prius Individual Battery Module Replacement' by member @ryousideways
    Rebecca Leyva likes this.
  2. Rebecca Leyva
    Rebecca Leyva New Member
    Colorado
    If they gave me diagnostic Trouble Code Report and told me the problem was my HV battery, would the sheet also tell me which battery block was faulty?
    52,927
    it's possible. certainly worth getting the info from them to see what it is.
  4. ChapmanF
    19,087
    If stuff is on, it definitely shows a discharged battery, but isn't incredibly low. Remember, C2318 is logged by the transmission control ECU, likely while it is trying to park or unpark, and the timing of that can happen to be when other electrical loads are active too; it probably indicates the battery has an open-circuit voltage somewhat above 9 (about 10½ is considered completely discharged for a typical 12 volt), just being pulled down to 9 by the load.
    This is a possibility that gets more press than it probably deserves. Don't forget that the actual logic circuits in the car's ECUs probably operate at 5 or even 3.3 volts; there's a lot of headroom even when the 12 volt battery is awfully low. Just by simple accidents like leaving lights on, I've seen mine pulled down to 7 volts during (unsuccessful!) starting attempts, and I've done this more times than I'd like to admit, but I've never seen the ECUs give me 'false' codes or dash lights as a result. They may give me completely accurate codes telling me just what stupid thing I did, and we saw that here too, where even at 9 volts, the ECU simply recorded, in a functioning and businesslike manner, that it had seen 9 volts, and exactly what was happening when it did.
    In your case, you are the proud owner of one trouble code pointing to each one, but probably neither one was caused by the other.
    -Chap
    Edit: I should add that I've also, quite uneventfully, recharged the 12 volt several times after such discharges that it reached 8 or 7 volts under starting load. Strictly speaking, yes, its expected life probably did become a hair shorter each time ... but to me, just having seen your battery hit 9 under load would not make me automatically give up on charging it.
  5. bisco
    52,927
    right. but if it isn't on, it's incredibly low.:cool: as for the glitchy computers, i can only refer you to the old 'stuff acting weird?' thread.
  6. Rebecca Leyva
    Colorado
    This has been very helpful! Thanks so much!
    I am taking it to a family relative tomorrow who is a mechanic for hybrids.
    $200 for a 12v battery is pretty high for me right now given the fact that I already paid the dealer $400 for a key and I am a college student ready to transfer to a four year institution in the fall.
    I am going to recharge the 12v battery on my car. I also was looking at the paper work of the diagnostic report and it seems that Block 06 has a low voltage of 13.71, while the others have a voltage of 15 or 14.9.
    I honestly think that while the dealership was programming my key, they left my car on since I did not have another key for them to trace. I think this is when my 12v battery began to drain like it did and once I drove it for 4 miles, the dash and the screen began to get all wacky with me. I also noticed a noise (like a loud machine) go off once I turn off my car. I am assuming that the battery is also doing that.
  7. ryousideways
    ryousideways Member
    35
    101
    Merritt Island, Florida
    The first time my hybrid pack took a dump was when I hit 114K miles. If you have the time you can rebuild it yourself. The second time my hybrid pack needed to be rebuilt my brake actuator assembly failed around the same time.
