Check engine light came on this morning-P0101
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by H00s13r, Jun 1, 2020.
  1. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    Since everything is running correctly, clean them, just to make sure.
    Then just drive the car. It may take a several cycles of the car starting/shutting off before it resets.
    When I cleaned the egr circuit a few months ago, I had forgotten to install the connector on the MAF sensor.
    At least it's the easiest one! :)
    I cleared the code a few times with techstream, but it kept coming back. I had read something on Prius Chat
    that the computer needs to see a consistent reading for X amount of cycles before it cleared the code.
    The light went off on it's own after a few cycles of stoping and starting the car. I had errands to run at several
    stores that day. I didn't even notice it was off until the next day!
    So maybe clean both sensors with the proper cleaner, clear the code. Then just drive it since it runs fine.
    Hopefully, in a day or two it will go off on it's own.
    And I would run techstream and test both sensors and verify either of them are bad before spending the money
    to replace them. Because you can't usually return electronic parts.
    pjksr02 likes this.
  2. ChapmanF
    19,016
    P0101 is basically a sanity check on the mass-airflow sensor:
    You can see what the ECM is doing there, it's kind of clever.
    First, it doesn't want to be making such judgments under any kind of extreme conditions, so it only does this check when up to operating temperature, and driving at moderate throttle.
    Then, it has two different ways it could calculate how much load is on the engine. The first way is from the mass-airflow reading; how much air is being charged into the engine is pretty much the by-the-book indication of how hard the engine is working.
    But the ECM is also built into a hybrid car that's bristling with other ways of knowing how much power is being asked of the engine, such as electrical readings from the transmission.
    So, if you have two different ways you could calculate the load on the engine, and you want to do some kind of basic sanity check, what could you do? Well, you could calculate the load both ways, and divide one answer by the other, and hope the ratio is pretty close to 1.
    Toyota, they picked some limits on both sides, and said if the ratio came out less than 0.829 (so the MAF reading says the engine is working less hard than the driving conditions indicate), or more than 1.153 (so MAF says the engine is working harder than driving conditions indicate), they're going to say "something doesn't add up here", and set the P0101 code.
    Chances are a discrepancy like that, in how hard the engine is "really" working compared to the airflow they think is going in, will also require largish changes in fuel injection to one side or the other of what would be calculated from the airflow, so they check for that too.
    You can see it's one of those trouble codes that covers two pretty-much-opposite scenarios—I mean, look at it one way, they're just saying "we defined a range we'll consider believable, and this code is for when things are outside that range", but look another way, there's a pretty big difference between the airflow reading telling you the engine is working less hard than you think, or that it's working harder than you think, and between the mixture coming out richer than you calculate, or leaner than you calculate. There would be pretty much different universes of explanations to check for, depending on which of those scenarios you're in.
    That's why the "inspection procedure" in the manual starts right off by reading the freeze frame from the ECM so you can see what the readings were when the code was set, and find out which side of normal things were off to.
    So probably following that procedure will be a good start. Sure, the EGR valve is one of the listed trouble areas, but don't overlook the rest of them either. Again, after figuring whether it seemed like more air or less air was flowing than expected, a bit of thinkery should come up with which areas might be worth a closer look.
    As far as taking the EGR motor apart and reassembling it, it's so mechanically simple in there I don't think there's very much to go wrong. If it's like the one I opened and the stator is rusty and touching the rotor, that could interfere with operation, but once the rust is cleaned up and the parts fit, it seems like if you manage to get the parts in place and stator snugged down so the flange is seated, you've probably done it right. :)
    Conveniently (for purposes of assembly confidence), I found it kind of hard to reassemble without the valve ending up slightly open. You can spin the rotor all the way down on the shaft, but the spring wants to spin it back up some, and sooner or later, while you're putting the stator back on, you're gonna have to let go. :) So the rotor spins back up a little ways, and then as you finish snugging the screws down, sure enough, you've pushed the valve a little bit open.
    The reason that's convenient is it gives you a nice easy way to confirm everything moves smoothly. Just plant your thumb on the slightly open valve pintle and push it back closed. It should not be very hard to do, and you should hear the rotor inside quietly whirring (no scraping or roughness) while you do. If that's what happens, I'd say you're good, as far as the EGR valve goes.
    It would be less convenient to test if you actually managed to reassemble with the valve completely closed, because then the only way you would have to test would be by trying to pull it open, and it's pretty hard to get a decent grip on for that (and I would be leery of trying to grab it with tools and maybe mess up the seating).
  3. Mendel Leisk
    42,341
    You do this just with the valve in your hands, not connected to 12 volt? It's purely a mechanical reaction? Or while connected to 12 volt? I haven't had the valve apart myself, not at all clear on the internals.
  4. ChapmanF
    19,016
    Yeah, just sitting in your hands.
    Making a six-terminal stepper motor (which is what that is) electrically turn is kind of a fussy business. You could make up a board with four two SPDT toggles or buttons and train yourself to 'play' it (one of 110 steps at a time), or a digital output board and write a little program to do it. Definitely not a "just tickle the terminals with a battery and watch it spin" proposition.
    In most cases, when you have any steady electrical connection to it (that you're not 'playing' in the right sequence for rotating one way or the other), a stepper motor will stay exactly where it is with great stubbornness. That's one of the things people choose them for. So the only time you're gonna find it easy to move by hand is when there's no power connected.
    #24 ChapmanF, Jun 2, 2020
  5. H00s13r
    H00s13r Member
    88
    27
    Indiana-NWI area, US
    I don't own a techstream, just a cheapo OBD reader that will allow me to clear codes.
    This morning I took out part of the airbox, cleaned the lower MAP sensor and let it dry, then re-installed it and double checked that I reconnected it. While airbox/air filter part I was off I double checked everything that I did, making sure all connections were done, I double checked the OCC tubing to ensure that it was still connected to the PCV on the intake, and the manfold on the out tubing. I also looked over all the EGR connections, cables, etc. I took off engine cover and looked under there too. Once all was good, I took off and cleaned the MAF sensor from the top part of airbox and let it dry was well before putting it back. Then reassembled airbox and lid, making sure all connections were done and tight. I then started up car and cleared the code. I will see what happens over the next couple of days.
    ASRDogman likes this.
  6. H00s13r
    H00s13r Member
    88
    27
    Ummm....Yeah... that is all well above my capabilities and understanding.;)Thanks though.
  7. H00s13r
    H00s13r Member
    88
    27
    Hello,
    Yes sir-double checked everything.
    I only bought new gaskets for the manifold (the small ring one where the pipe goes into and the 4 oval ring ones that go on the other end. I wound up re-using the gakset from the throttle body and all the original gaskets on the EGR assembly. I double checked that I had them all on the right way when I put it back together.
    No I didn't try taking OCC out of the equation-I didn't think that was the problem since so many have done it on here without any problems.
    Today I cleaned MAF and MAP sensors today with some MAF cleaner and then put everything back, double checked all connections, and cleared the code.
    I appreciate your offer of your old EGR valve, but before we do anything, lets see if what I did today will keep the code from coming back.
    If it comes up again, I will try your suggestion of taking OCC out of the loop and just connect original tubing from PCV to manifold (I wound up not cutting it, so I should just be able to pop it back on. )
    If I get to that point, and still having this problem then I will hit you up on your offer of your old EGR. Thanks!
    pjksr02 likes this.
  8. ASRDogman
    8,063
    4,086
    Hopefully it will clear the code soon.
    pjksr02 likes this.
  9. H00s13r
    H00s13r Member
    88
    27
    Just want to update everyone. So since cleaning MAF and MAP sensors, and double checking all connections, I have driven over 30 more miles on it and no check engine light!
    Today I cleaned/vacuumed car, and then did the take down of the back to do the hybrid battery fan cleaning. The only part I struggled with was getting that rear seat out! The guy in NAB just pops it up, but mine wouldn't pop out of those front clips and the seat was starting to tear at that joint. What I wound up doing, and figure I would share it here is I reached in at the back of the seat and using both hands I pushed rear of seat down to get it off that back hook on each side. once the rear of the seat was no longer on those hooks, I tilted the seat up toward the front seats. This then allowed me to grab the seat where those metal clips are in the front and then I was able to pop out the front part of the seats from those clips. Just don't push the seat too far forward before removing as you can bend the metal parts that go into the front clips.
    After that the rest was cake.:)I also would suggest taking positive terminal off rear battery since you will have your doors and hatch open the entire time. I did this so I didn't drain battery. I also did thorough cleaning of the back area, vacuuming in those areas behind seat, etc.
    I found that once I had the fan out, I tried cleaning with my compressor by blowing air on fins. This got some of the looser dirt off, but I wound up taking fan housing apart. It is really easy, just 3 small screws and then you can carefully unclip the front plastic cage off. You will see at the foam connections around the part that the plastic intake connects to. it doesn't look like you can separate it, but you can-the foam has a break where the two halves come together. Then using carb cleaner sprayed on Q tips (I don't recommend spraying anything directly on fan fins as you might spray into housing where electronics/fan motor are) I gently cleaned in between each fin. It did take a while, but after about 30 minutes the fan fins looked brand new. I also cleaned the front housing and rear by gently wiping with paper towels with carb/brake cleaner lightly sprayed onto paper towel. once all parts were clean, I used my compressor again and blew air on all parts to ensure were all dry and free of any cleaner residue.
    I also cleaned other plastic parts you have to remove to get fan out. The plastic housing behind that piece of trim with the grille air inlet was pretty dirty so I gave it a good cleaning. I cleaned all other parts as well and then carefully put everything back together. Lastly hooked positive terminal back onto battery and started up and made sure I didn't get any check engine light. If anyone has any questions on this or needs help, please let me know. Thanks to everyone who helped me with this and my previous thread of the EGR/manifold/OCC stuff.
  10. ASRDogman
    8,063
    4,086
    I'm very happy for you! And glad it was something simple.
    Both MAF and MAP sensors are very sensitive. Glad cleaning them took care of things.
    With the rear seat, they are TOUGH! Stupid idea!
    I use a pry bar carefully to push up on the seat on one side of the clip and my fingers on the other,
    then give it a good yank. It's till a pain!
    Thanks for the update!
  11. H00s13r
    H00s13r Member
    88
    27
    You're welcome. I am glad that the car is back to itself and running a little better
