Check Engine Light: Chewed Sensor Wire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Starbrand, Jan 12, 2017.
  1. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    engine light kept coming and going. one day it would be off, another day it would be on. apparently a rodent of some sort has found warmth underneath my car and decided to chew on the sensor cable. Any alternative fixes than getting dealership to replace($310 parts&labor)? I thought about just electric taping and getting some hard tubing to put around it. But not sure if that will fix my check engine light issue.
    any other solutions? any part number so I might be able to do it myself?
    52,848
    if you are sure that is the problem, you probably need to repair the wire. how much is the part, is it difficult diy?
  3. mrbigh
    3,686
    699
    Long Island, NY
    electrical tape will do the job in a jiffy. You may try to install an spiral plastic loom around the length of the exposed green cable.
    Radio Shack used to carry the accessory.
    #3 mrbigh, Jan 12, 2017
  4. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    I park on top of an electric rodent gizmo, no mice wanted, actually two of them;)
  5. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
  6. tankyuong
    1,555
    662
    Central MO
    I would heat shrink tube it
  7. bisco
    52,848
    my thoughts exactly.
  8. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    I can repair cable blindfolded (have done such on dark stages and under cars....two totally different bit same industries).
    In all seriousness- it just needs to be spliced....about 70 seconds worth of work, literally. Find the wire and do it yourself. Don't pay a dealer hundreds for this
    #8 Jimi1976, Jan 13, 2017
  9. ChapmanF
    19,019
    Might want to wrap the repair (and whatever nearby looks tempting) in some rodent tape.
    The trick is you have to judge what would look tempting if you were a rodent.
    -Chap
  10. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    I have had similar problems and decided to reduce the mouse population. These traps are so much better than the simple little traps that have been around forever.
    They are easier to set and easy to release the remaining carcass.
    Montgomery likes this.
  11. mrbigh
    3,686
    699
    Long Island, NY
    A moderate size heat shrink tubing for this need will not pass trough the Oxygen sensor, with such wide body.
  12. Mendel Leisk
    42,343
    If you're getting a warning light I think there's a very likely one or more of the internal wires is broken or or seriously compromised. That needs to be remedied, say resoldered, perhaps some fresh wire to bridge gap, insulated, and the then the whole cable re-wrapped, and perhaps "hardened" against return visits by the vermin, lol. Is it easily disconnectable?
    How much was the labour, vs just the part, btw?
    #12 Mendel Leisk, Jan 13, 2017
  13. slewinson
    slewinson Junior Member
    36
    30
    Australia
    Replace the oxygen sensor - it is a ten minute job! Go to the Toyota dealer with the vin and the photo that you posted. The cable is part of the calibration and may cause other issues if spliced. That area also gets hot and a repair may not last or remain totally waterproof.
    Simon
  14. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    You can buy O2 sensors a lot cheaper online then the dealer
  15. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
    What electronic device would this be?
  16. Mendel Leisk
    42,343
    Does the cable run into the oxygen sensor without a connector? I gather that's what you're saying, just curious.
  17. slewinson
    36
    30
    Australia
    No, the oxygen sensor generally has a lead about 6-12 inches long with a connector on the end of it. Going by the picture this pigtail is what is damaged.
    Simon
  18. Mendel Leisk
    42,343
    Then why replace the sensor? Maybe the cable alone is not available?
  19. slewinson
    36
    30
    Australia
    Brcause the pigtail is part of the sensor! Google images will assist you.
    Simon
    Rebound and Mendel Leisk like this.
