Check Engine Light, Engine Knock
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Marcilla Smith, Jan 9, 2019.
  1. padroo
    padroo Senior Member
    2,763
    2,253
    If I was you I would call the Toyota dealer and find out if your car has ever been in the shop for that
    TSB, they record things like that, you will need your VIN number.
    Marcilla Smith likes this.
  2. Marcilla Smith
    Marcilla Smith Active Member
    140
    125
    Raleigh, NC
    When I called my local Toyota dealership, the person I spoke with would only say that there were no outstanding recalls on my vehicle. When I asked if it would help if I gave her the TSB, she told me a TSB and a recall are the same thing. Her response to everything was to stonewall and push for me to set an appointment. I thanked her for her time.
    As for the knock, I tried some Techron Complete Fuel System Cleaner I picked up at Discount Auto Parts for $5. THIS STUFF WORKS!!!
    It says to wait until the tank is almost empty, but with mine still at 4 bars, I poured it in and filled the tank. Within a few miles, the knocking was noticeably diminished. With the gauge still at 10 bars, I couldn't hardly make it "rattle" no matter where it was in the range of speed or how much accelerator I gave it. And to think I was worrying I might need a new ICE!
    For anyone who thinks they might have pre-ignition or otherwise hears a knock or "engine rattle," I hope they will at least consider spending the $5-10 to see if this can save them a trip to the mechanic!
  3. Mendel Leisk
    42,276
    If you're not doing this tank after tank, I don't think it really matters to have the tank near-empty before using this. Even with just half a tank of gas used, if you pour in that bottle, then fill the tank, it will be well mixed.
  4. padroo
    2,763
    2,253
    It's the nature of electric fuel pumps to churn the gas in the gas tank. Fuel pressure regulators either with a return line from the fuel rail or returnless systems send fuel back into the the gas tank to maintain constant fuel pressure.
    Anytime you put a fuel additive in your tank it will get mixed.
    Marcilla Smith and Mendel Leisk like this.
  5. Mendel Leisk
    42,276
    I've looked for Techron in the past, doesn't seem to be available up here. I've been trying this:
    MotoMaster F1 Extra-Strength Fuel Injector Cleaner, 473-mL | Canadian Tire
    It has PolyEtherAmine cleaner. Not sure what they mean by "1/2 bottle", in the above link. The bottle says to use one ounce per 16 liters (good ol' Canadian messed-up Metric). I believe the 473 ml bottle is in fact 16 oz.
    Sitting in the driver's door bottle holder. Fits nicely. Want to dose it next fillup.
    It's really cheap, goes on sale for half-price every so often (about $7 CDN), and with recommend dose (a bit under 3 oz for 45 liter Prius tank), it's about 5~6 usages. I'm figuring to use it about twice yearly, sorta synced with the spring/fall oil changes.
    #25 Mendel Leisk, Apr 18, 2019
  6. Patrick Wong
    18,210
    6,517
    A technical service bulletin makes the Toyota dealer techs aware of a known issue.
    A recall advises Toyota owners of a serious defect which requires dealer service.
    The two are different concepts. Recalls would be a subset of all issues which require a TSB.
  7. Marcilla Smith
    140
    125
    Raleigh, NC
    Depending on the level of PEA, that seems like a really good price for 16 tanks worth :)
    Meanwhile, I am still left ignorant of whether the firmware update has been applied. Is there a way to check this myself? I prefer DIY to putting my faith gullibility in the dealer
  8. Mendel Leisk
    42,276
    Well, more like 5~6 tanks. Still, for $7 CDN, yes, good price.
    Using the the dispensing bottle is an "art". Someone here clued me in: loosen the cap on the small measuring bottle, and keep the main bottle cap tightly sealed. Then squeeze the main bottle, and the dispensing bottle can be slowly filled. It only holds 2 oz, so for the approx 3 oz required for a prius gas tank, you've got to do the process twice.
    Dealership is best bet for update checks I think. As far as I know they just need the VIN??
  9. Marcilla Smith
    140
    125
    Raleigh, NC
    Yes, I missed the part about "3 oz."
    Apparently my local dealership is going to need more than the VIN. More like a course in customer service :: eye roll ::
    Maybe I'll try emailing?
  10. Marcilla Smith
    140
    125
    Raleigh, NC
    Hello my name is S***** and I'm here to assist. I can set an appointment up for you. When is the best time for you?
    Thank you,
    S***** C****
    Service Care Coordinator
    336-398-**** (direct line)
    336-288-****/**** ( Main Line)
    R*** Toyota
    **** Battleground Ave.
    Greensboro, NC 27408
    So much for that idea...
    I tried looking online for how to recalibrate the ECU. I found what seemed like it might have the SW to DL for the EU market, but not NA :: sigh ::
    Any other ideas for DIY before I take it into a (non-dealer) hybrid specialist?
  11. DThrill
    DThrill Junior Member
    Phoenix, AZ
    when my Prius had engine knock codes registered bad engine coils... turned out to be LEAKING INVERTER FLUID into engine cylinders from bad head gasket. Had to get half of the engine rebuilt.
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Inverter fluid is a separate loop and only services the Inverter does not come anywhere near the engine.
    If your talking about the 2010 its probably had big EGR issues and head gasket issues like every other 2010 out there.
    Marcilla Smith and padroo like this.
  13. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    If performed, the dealer service should be logged at https://toyota.com/owners
    And per the TSB (pages 5 and 6), there would've been a sticker placed under the hood. Though they could've ran out of stickers :whistle:
    Marcilla Smith and Raytheeagle like this.
  14. Marcilla Smith
    140
    125
    Raleigh, NC
    After flashing the ECM then idling the vehicle overnight and driving from Raleigh to Greensboro, I can say that so far there is no MIL.
    Furthermore, there is now absolutely NO engine knock at any speed or level of acceleration. Additionally, a highway MPG test over 30 miles showed 52 MPG whereas a similar test previously showed 44!
    Anyone who has never had the ECM updated because there were "no issues" but is getting the typical (according to fuelly) mid-40's on highway MPG may want to consider looking into getting the ECM flashed
    SFO likes this.
