Check Engine light EVAP code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gray Badger, Nov 18, 2020.
  1. Gray Badger
    Gray Badger Junior Member
    Carmel, IN
    Hello all!
    Check engine light has come on a few times in past 2 months, got code read at auto zone and both times said EVAP was the result...the shop I usually go to said they don't have the parts to fix it, and if there's an issue (they seemed to think EVAP code not a big deal) I should go to dealership...any experience with this? I'd rather not continue to see the check engine light and have to check the code every time and also want my car to be in good shape of course! Thank you!
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Did autozone give you the OBD2 code (DTC), and can you please post it here for additional guidance?
  3. Gray Badger
    Carmel, IN
    Yes! P0446
  4. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
