Check engine light on 2015 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kutztown46, Sep 26, 2021.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,571
    2,602
    Taylors, SC
    You might want to invest in the Scan Gauge 2,
    I can really depend on my Scan Gauge 2 to continuously monitor the status of the systems in my Prius v.
    I configured mine to monitor the 12 volt condition, the water temperature of the engine coolant, the temperature of the inverter and the traction battery temperature all at once.
    Noticing that there is a rise in the ICE's coolant temperature would have alerted you even if the check engine light was not triggered.
    Alternatively, there are many other different parameters that you can also monitor, if that is more important to you.
    If there is an OBDII fault code or CEL , I can access it readily by pushing a few buttons, a function I fortunately have not had to need to use.
    The photo shows the display that I monitor with the Scan Gauge 2 mounted on the top of the steering column. Scan Gauge 2.JPG
    Whenever my dealer worked on my car, all they dis was to unplug the Scan Gauge from the OBDII port, did their work and re-plugged the Scan-Gauge back in. It works automatically all the time when the car is turned on, especially when the ICE is not running.
    There are no apps to open. Pushing one button switches to reading a fault code.
    #21 Georgina Rudkus, Oct 9, 2021
    dig4dirt likes this.
  2. Mendel Leisk
    42,305
    Sadly I had to give up on my SG: not sure but apparently having it constantly weighing on the OBD port was the cause of increasingly frequent Check Hybrid Warnings and brakes reverting to default behaviour.
  3. Georgina Rudkus
    3,571
    2,602
    Taylors, SC
    No such problem. I tied the extra cable to a point under the dash. There is no extra weight on the OBDII connector.
  4. rjparker
    rjparker Tu Humilde Sirviente
    11,049
    6,923
    Texas Hill Country
    Most likely it was a CAN bus problem. Others have reported similar issues with SG2. Some suggest not connecting the cable when the vehicle is on even though the instructions seem to suggest the opposite. Others blame SG2 firmware revisions.
