Check Engine Light On and Accidentally Erased Codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mattdr28, Sep 13, 2021.
  1. Mattdr28
    Mattdr28 Junior Member
    28
    Washington, DC
    My check engine light came on suddenly the other day. I just had a 145,000 mi service about a month ago. I plugged in my OBD scanner and accidentally pressed the reset code button on the Dr. Prius app before I was able to get the codes. I ran the emissions test using the Car Scanner ELM app and it says the O2 sensor failed the test. Does this mean the O2 sensor needs replacing? Should I run another 50-100 miles to see if the check engine light comes on again?
  2. nancytheprius
    nancytheprius Active Member
    356
    152
    iowa
    if nothing feels or sounds wrong when running/driving, I wouldn’t replace the oxygen sensor until you get the original codes that were cleared. I’d recommend driving some more until the light comes back
  3. Mattdr28
    28
    Washington, DC
    What about an evap system leak?
