Check Engine light on any one had this issue before? code p1121 coolant valve
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sockmonkey, May 29, 2014.
  1. sockmonkey
    sockmonkey Junior Member
    84
    texas
    I guess since you put it so easily that way and they had reworded it.....
    I am just happy to have some peace of mind that my car will last me a little longer until I start my new job hopefully and relieve some stress during my training period, so I won't have to worry about transportation to and from.... Thanks for the help everyone.... sorry I couldn't DIY ... it just didn't think I would be able to do it properly.
  2. JC91006
    16,939
    8,647
    I gave you the short version, but it probably was more complicated. Glad you're on your way to some more trouble free driving
    SM-N900P ?
  3. stevo7896
    stevo7896 Junior Member
    Fresno CA
    I live in Fresno CA and they don't require any smog instection here in CA .We are one of the most strict counties in the US. Im shocked they would do an emission test anywhere else.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    This is the inverter coolant pump I presume.
    I thought it could be replaced under warranty.
  5. KhaPhoRa
    KhaPhoRa Member
    168
    37
    Well think about it.. It would require either the legislative body of the state or some regulatory board to specifically take action to grant an exception to a certain type of vehicle when the old rules state "all vehicles...." (As they do here in Texas). Honestly I'm surprised CA would grant an exception to a vehicle that is perfectly capable of excessively polluting the skies by having a catalytic converter, mass airflow sensor, o2 sensor, gas cap or anything else related to emissions fail. Ok after doing some reading it seems the exemption was added in CA not because they think the cars cannot pollute, but because the emissions testing methods used are not compatible with the no-engine idle behavior of the prius. So I'm guessing CA requires a probe in the tailpipe method? I've seen a few mentions that CA will drop the exemption in 2015 when testing methods are modified (I don't see why they don't simply use the OBD2 method).
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    Easily solved by putting the Prius in diagnostic mode, but don't tell the regulatory bodies.
  7. KhaPhoRa
    KhaPhoRa Member
    168
    37
  8. JC91006
    16,939
    8,647
    You're not suppose to drive in this mode. The test requires the wheels to move
    SM-N900P ?
  9. SageBrush
    11,627
    2,533
    Southwest Colorado
    Interesting. Do you know why ?
  10. KhaPhoRa
    KhaPhoRa Member
    168
    37
  11. JC91006
    16,939
    8,647
    The reason for wheels to move or why you're not suppose to drive in that mode?
    I don't know the reason, I think I'll find out.
    SM-N900P ?
  12. Patrick Wong
    18,214
    6,531
    The reason the front wheels have to spin is because CA uses a dynamometer emissions test.
    The reason you are not supposed to drive the car when in maintenance mode is because in that mode the wheel slip control is deactivated; hence it is possible to damage MG2 if the wheels spin excessively.
    #32 Patrick Wong, Jun 10, 2014
  13. jgagne
    jgagne Junior Member
    FYI...my 2005 showed code P1121 yesterday after I let the car idle quite a while while I adjusted the HID headlights that the dealer really screwed up. Since I was out in a school parking lot with a flashlight and a wrench, took me a while since one light was searching for lost birds and the other was looking for snakes....lol. Long story short, plugged in my OBD II from Harbor Freight and saw the code. Looked up the bad news and read lots of info on Priuschat. Thought I would take a guess that it might have something to do that I had it idling for probably 45 minutes (and my engine runs more than what I think is normal) so I pulled my negative battery terminal and erased the code in the car after erasing the one on the OBD II. Waited a min, connected it and prayed. No Check Engine Light or Code. Ran 9 hours of errands today to 15 places in 85 degree temps, and (knock on my head as wood) no light or code.
    Just thought this might help for anyone in higher temp areas that might have been idling a long time or totally stop and go traffic and then get the light and code. Not saying yours may not come back, but would sure be nice to be able to rule out a false positive, which is what I think I had from the car just overheating from just sitting and idling for so long....also with forgetting to turn the air conditioner off also....oops. Oh well, hope it helps someone.
