Check engine light - P0171 system too lean -- buy new MAF sensor?
Discussion in 'Gen 3 Prius Technical Discussion' started by Doug Hansen, Jul 13, 2026 at 4:22 PM.
  1. Doug Hansen
    Doug Hansen Junior Member
    Carlsbad, CA
    I've cleaned the MAF sensor with the special sensor cleaning spray, and it worked for about 4 days but now the check engine light is back on and the same error code is P0171. Gemini says I should try clean the sensor contacts again, so I will, but if I need to buy a replacement MAF sensor, so I spend the $150 on a Denso or the knock - off that gets a 4.4 rating on Amazon and costs $25? Very few people have bought the OEM Denso, not sure why.
  2. Brian1954
    Brian1954 Senior Member
    2,658
    1,060
    South Central PA, USA
    What year is your Prius, and how many miles are on it?
    In most cases, the problem is not the MAF sensor. It is an air leakage problem. Check all the vacuum hoses for cracks or splits on the end of the hoses where they connect.
  3. Doug Hansen
    Carlsbad, CA
    Hi Brian, it's a 2011 Prius with 101,000 miles. Hoses look fine. Clamps fine. Car has been regularly maintained. I followed Gemini and used the official spray cleaner on the MAF wires (twice) and at first the Check Engine light stops, but after a couple of miles it comes back on. So my AI "friend" says the next step is to replace the MAF sensor. Then go to mechanic and have them work on the EGR. I'm no mechanic! Ideas?
