Check engine light
Discussion in 'Gen 4 Prius Technical Discussion' started by Frederickdawg, Dec 25, 2017.
  1. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Steam coming from under the bonnet is a reasonable indicator of overheating coolant, or worse!
    kithmo, Mendel Leisk, Adam1a and 3 others like this.
  2. johnsontsui
    johnsontsui New Member
    Japan
    (y)
    yes, you are right
    Raytheeagle likes this.
  3. Frederickdawg
    Frederickdawg Active Member
    596
    337
    Florida Unfortunately
    So the check engine light after around three starts and a few days is still present.
    Does it need to be reset by dealership or will it eventually go off by itself?
    SM-N950U ?
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    There could be a code for many different reasons.
    Did you try Carista and see if the codes can be read using it?
    I’m pretty sure you can as it has a “diagnose” choice, but have not used it.
    If you have ELM device that plugs into the OBD2 port, you can buy another app to read the codes. They can be had for less than $10.
    Usually after 3 driving cycles when the car confirms everything is back to normal, it turns the light off.
    But if the reason is different, it will set the light again.
    Best to try and read the code and see what it is saying.
    Hopefully the gas cap is it(y).
    #24 Raytheeagle, Dec 31, 2017
    RCO likes this.
  5. bisco
    52,697
    someone said you need at least a 20 mile drive in another check engine thread.
    RCO likes this.
  6. Frederickdawg
    596
    337
    I connected the Carista and it took a while to read the codes. Came back with the following.
    SM-N950U ?
  7. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    P1423 is an evap system leak, most likely from a gas cap;).
    How far or how many drive cycles has the Prius done since the incident?
    Did you reset the code?
    Does your wife know the reason the check engine light came on?
    Keep us posted (n).
    #27 Raytheeagle, Jan 1, 2018
  8. Prodigyplace
    12,708
    11,847
    Central Virginia
    Typo??
    #28 Prodigyplace, Jan 1, 2018
  9. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Unfortunately :(.
    But eBay = evap;)
    Silly auto correct :cool:.
    RCO and Mendel Leisk like this.
  10. Mendel Leisk
    42,202
    Just to chime in on the engine coolant temp gauge phase out: I miss having it. It's good for monitoring warm-up, which is instrumental to improving mpg. If you're doing any grill blocking, using a block heater, many reasons. Rolls Royce would be a numeric display of temp. I had this with my ScanGauge, but it (apparently) started playing silly-beggars with the OBD port, I've had to disconnect it.
    RCO likes this.
  11. Frederickdawg
    596
    337
    Yes, I reset it via Carista. Hopefully that will be the end of it. She did over 3 drive cycles of which one totalled over 40miles during the few days since I secured the gas cap as it wasn't seated correctly.
    SM-N950U ?
    RCO and Raytheeagle like this.
  12. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    That's the biggest hint a gal could give her man to fill the car for her next time, without need for a 'pretty please'.
    krmcg, Prodigyplace and Raytheeagle like this.
  13. Frederickdawg
    596
    337
    The honeymoon period ended almost a decade ago. ;-)
    SM-N950U ?
    pjm877, RCO and Raytheeagle like this.
  14. Prodigyplace
    12,708
    11,847
    Central Virginia
    Perhaps that is why more than a mere suggestion was needed :eek: :oops:
    jtv and RCO like this.
  15. Bham_prius
    Bham_prius Junior Member
    35
    bellingham
    I just did a manifold clean, new plugs, ERG cooler etc and I have a check engine light on, hoping after a cycles it goes away - but I know what you mean by sweating it!
