Check engine light
Discussion in 'Gen 3 Prius Main Forum' started by Adrian17, Jul 28, 2018.
  1. Adrian17
    Adrian17 New Member
    San Francisco
    can a dirty passenger cabin air filter or dirty engine oil cause the CEL to come on?
  2. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    It can cause your egine to sieze.
    Raytheeagle likes this.
  3. FuelMiser
    FuelMiser Senior Member
    1,299
    887
    Monument, CO
    CEL comes on for Emissions Control issues: catalytic converter, fuel vapor containment (gas cap), etc.
    49,446
    welcome!
    cannot be caused by dirty filter or oil.
    2015? probably the loose gas cap mentioned above.
  5. BZzap!
    BZzap! Senior Member
    1,607
    877
    Until you have the fault codes read, it’s going to be a blind guess. If you don’t have a scanner, take over to AutoZone or other parts place and have it scanned (free). Then post the fault code on this thread. Then, maybe someone can help you sort it out.
