Check Engine Light
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by PGX, Oct 17, 2018.
  1. PGX
    PGX New Member
    700 Sylvan Ave., Englewood Cliffs, NJ 07632
    I was wondering if anyone else was having a similar issue. The check engine light has gone on 3X in 2 years. Once because the gas cap wasn't screwed on tight enough and the other times because an acorn got stuck in the grille. I didn't see the acorn when I've checked the grille. The dealership is going to replace the grille, but I don't think this will resolve the issue because the grille has been replaced before when the bumper was replaced and it happened again with the new grille. It's really annoying and will become expensive when the warranty expires if I have to continuously bring the car in to have them inspect the check engine light.
  2. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    Never had a CEL in 2.5 years (15K miles)
  3. Mendel Leisk
    38,729
    So likely the active grill shutters jamming.
    alanclarkeau likes this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Never had it come on - but I don't think I've got active grille shutters.
  5. bisco
    49,500
    any way to disable the grill shutters without throwing a code?
  6. Elektroingenieur
    2,515
    3,259
    Three Touring
    You might ask the dealer whether they used the new grille shutter parts specified in service bulletin T-SB-0319-17, “MIL "ON" DTC P05A072 Due to Debris Stuck in the Active Grille Shutter,” described in my previous posting.
