Check Engine / Triangle of Death / Exclamation Point
Discussion in 'Generation 1 Prius Discussion' started by garywhite, Dec 7, 2012.
  1. garywhite
    garywhite Junior Member
    25
    Oakland, CA
    2001 Prius
    My 2001 Prius has for the third time in approximately 4 months given me the combination of errors, Check Engine & Triangle of Death on the dashboard and Exclamation Point on the LCD.
    Each time the problem has cleared itself in less than 24 hours. The last time it happened I borrowed a friends OBDII scanner and connected it to my Prius. It gave me the error message Engine Unable to Start. As the engine has never had any issues, even while the error codes were being displayed, I assumed the scanner was feeding me misinformation.
    This afternoon when I was presented with the error message again, I started driving down the street and found the car's top speed to be 35 MPH. Which I think I recall is the maximum speed while on battery. So I stopped at a nearby gas station and found the oil to be low, I put in enough oil that the gauge was reading better than half full, let the car rest for a minute, and started it up. This time I was able to accelerate past the 35MPH limit.
    I'm not quite sure what my next steps should be but would welcome any advice. This car is otherwise very reliable, I've had to replace the 12v battery on it more times than I feel appropriate, and it is worth noting the car just passed 300k miles so it is no spring chicken. but overall it is a reliable.
  2. bwilson4web
    16,523
    These are usually some sort of "P" code. Sorry, I can't help.
  3. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    If you scan the car and get codes P3191 and P3101 thoroughly clean out the throttle body and liquid at bottom of intake manifold under the throttle body. That is often the case with "Engine doesn't start" errors.
  4. beanmat
    beanmat New Member
    22
    New Port Richey Fl.
    2003 Prius
    I got the same car(pic) with an exclamation mark through the middle and was unable to keep the car running
    although it would start up allright. Towed it to the Toyota Repair shop and found only a "no start related code"
    after diagnosis and said they found some oil in the intake man. , performed a top eng. clean service , installed Toyota irridium plugs and replaced airfilter under hood , some of these things I could have done myself. However since I
    was on the road I had it done, The car runs fine now, and I wonder if this is treatment will last .
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    Gary and all,
    Just so you know, if you put the car in "R" or "D" b4 the engine starts, the car will give the symptoms indicated and revert to OutOfGas mode. It sounds like this is what might have happened. I have done this several times and it took a while for me to figure it out.
  6. garywhite
    25
    Oakland, CA
    2001 Prius
    Sorry for the delay in responding, I've been lucky enough to be on vacation! So as it has done in the past, the error message dismissed itself, and the car is running fine again.
    3ProngPaul, is cleaning out the throttle body and liquid at bottom of intake manifold under the throttle body something an amateur could attempt?
  7. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Personally, I would get the codes and post what they are here before spending time/money on blindly trying to "fix" problems.
  8. usnavystgc
    3,159
    990
    Tucson, AZ
    I just about guarantee you that you put the car in D or R before the engine started. After driving this car for a while, you get so used to just turning the key to start then putting it in gear. Sometimes you actually beat the computers in the car and it gets in gear before the engine starts. This really freaks out the ECU's (probably due to an unexpected sequence) and it throws codes (TOD and CEL and Exclamation)and forces the car into OOG mode.
    The way to know this happened is the codes and lights (obviously), the engine won't start and the car will only have electric power for acceleration. If you pull over, turn the car off, wait 30 sec's, turn it back on, let the engine start and then put it in drive, the car will function normally (all the lights will remain on). To clear the codes, four cycles of the ignition switch will clear all but the CEL and if there are no other problems, the CEL will clear with time.
    This is an anomaly common only to the Gen I.
    I do agree w/ cwerdna though that the best idea is to have the codes read b4 fixing anything. I've never been a fan of fixing things b4 I know their broke.
    SteveWlf likes this.
  9. garywhite
    25
    Oakland, CA
    2001 Prius
    While the problem is occurring I can stop and restart the car and the Triangle is persistent, so I don't think that it is that I got the car into gear ahead of the computer. It just eventually clears itself within a half day. I'll have to get the code re-read because I didn't write it down and it has slipped my mind at this point.
  10. usnavystgc
    3,159
    990
    Tucson, AZ
    What is meant by "the triangle is persistent"? When you say it clears w/in a half day, is that 4 cycles of the ignition/key? Does the triangle clear?
  11. 3prongpaul
    956
    735
    While it is best to have someone with a hybrid capable scanner read all possible codes, you can have AutoZone or similar read the codes for free...Engine/emissions related codes can usually be read by the cheapo scanners and that is better than no scan at all.
  12. garywhite
    25
    Oakland, CA
    2001 Prius
    Sorry I'm not being very clear with this. The triangle does eventually clear, 4 cycles is not an exact number. While the car is reporting the Check Engine / Triangle of Death / Exclamation Point, it happens every single time I cycle the car. Eventually, usually within half a day, all three of these symptoms disappear.
    3prongpaul, the O'Riley parts store here doesn't do scans anymore. I'll see if Autozone still offers the service.
  13. 3prongpaul
    956
    735
    I just noticed you're in California. You're SOL. For some reason CA stopped allowing parts stores to do free scans...you could buy a cheapo scanner at Autozone or Harbor Freight to have in your toolbox....like I said, a crappy scanner is better than no scanner. If you have an Android device with Bluetooth you could get Torque and a dongle like this one Amazon.com: Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner: Automotive
  14. garywhite
    25
    Oakland, CA
    2001 Prius
    Yeah I was pretty sure I had asked AZ last time this happened and was told no but was hopeful I was wrong. I think I might just end up buying one, I don't need it right away so I can wait and get one cheaply online. Given this problem and the fact my car is high mileage it'll probably be something I need from time to time.
  15. ChapmanF
    18,996
    Don't forget there's also the ScanGauge II, which you can buy right here and support PriusChat. It can function as a standard code scanner, plus you can program it to extract Prius-specific codes and information from the HV and battery ECUs using XGAUGE codes you can find in this forum.
    To use it in the Gen 1 Prius you need a slightly different cable, which the manufacturer will send you at no cost when you tell them you have a Gen 1.
    -Chap
  16. usnavystgc
    3,159
    990
    Tucson, AZ
    Allright, let's take a step back and make sure we have all the data correct in our (my) minds.
    Here's the symptoms as I see them
    1) When you turn the car on in the morning, you get, TOD, CEL and Exclamation (every day???)
    2) Half way through the day, all 3 indications clear (how many cycles of the ignition?)
    3) The next day the same thing starts over?
    Regardless of whether or not this is the exact scenario, for us to properly troubleshoot it, we need to know 4 things
    1) Are you 100% certain you are not putting the car in gear b4 the ICE fires up?
    2) If yes on 1), then the codes need to be read and the results posted here
    3) Are there any driveability issues at all (decreased mpg, decrease in power, missing etc)?
    4) What is the voltage on the 12V battery at rest and under load?
  17. garywhite
    25
    Oakland, CA
    2001 Prius
    Find my answers inline in italics
    Yes all three appear, no it is not everyday.
    Correct, all three clear. The number of cycles is not an exact science, more than 3 less than 12 is as specific as I could be
    No, this is an irregular problem. It has happened three time in approximately 4 months
    I wouldn't put my life on it, but I'm pretty confident that this is not the problem. I know that while the problem was happening I have cycled the car on and off several times, never putting it into gear at all and the problem would still present.
    I know these codes are hugely important for diagnosis, but this will have to wait as I do not currently have access to an OBD scanner. I'll work on getting ahold of one.
    None
    4) What is the voltage on the 12V battery at rest and under load?[/quote]
    Currently unknown, but this I can get a multimeter on
  18. usnavystgc
    3,159
    990
    Tucson, AZ
    Hey Gary,
    Well, we're getting somewhere. When you answered question 1), you say
    Regarding "the problem would still present", what would it present? Is the answer TOD, CEL and Exclamation but no driveability problems? If so, it is very likely you put the car in gear b4 the engine started.
  19. garywhite
    25
    Oakland, CA
    2001 Prius
    Yes it presents the TOD, CEL, and Exclamation Maybe I just don't understand the nature of this problem, but if I were to start the car, never putting it in gear and was presented with these three alerts it could still be an indicator that I had previously put the car into gear preemptively?
  20. usnavystgc
    3,159
    990
    Tucson, AZ
    Yes, if the errors (TOD, CEL etc) were not cleared by either unhooking the battery or 4 or more cycles of the ignition switch.
    What I'm saying is, If you initially placed the car in gear prior to the ICE starting, you will get the error lights (TOD etc). If you turn the car off and back on, the lights will not go away but the car will operate normally. If you disconnect and reconnect the 12V battery, the lights will go away or, if you cycle the ignition switch 4 times, the TOD and Exclamation will go away (provided no "real" faults exist). The CEL will go away after 5 or 6 cycles of the ignition switch.
    The possibility that you may have previously placed the car in gear prior to the engine starting (ie a month ago), would not cause the errors to display. They will only display right when you do it. If the errors are coming up without putting the car in gear, your problem is not related to this anamoly.
