Check Hybrid Light Only After Long Climb
Discussion in 'Gen 3 Prius Main Forum' started by Stephen Ross, Sep 16, 2022.
  1. Stephen Ross
    Stephen Ross Junior Member
    Lagunitas
    I
    “Check Hybrid Light” Only After Long Climb 1500ft+
    52,742
    probably too much heat and stress on the battery, egr, cooling fan
  3. Stephen Ross
    Lagunitas
    I
    70,000 miles on replacement HV battery that Toyota replaced on warranty at 140000 miles. Dr Prius shows no codes and 70% remaining on the replacement HV battery….
  4. Stephen Ross
    Lagunitas
    I
    Thanks, that had occurred to me….What should the max temperature be on the middle module?
  5. bisco
    52,742
  6. Stephen Ross
    Lagunitas
    I
    Thanks again…..Bumblebee says temp should not be above 110….at times I’m at 118, so that could be the issue….I tried to access the HV battery fan for cleaning today but getting to fan was more involved than I had time for….
