Check Hybrid System 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by clearblue, Feb 28, 2015.
  1. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    There's an area on the connector you have to squeeze to release a latch that holds the mating parts together. Disconnecting allows putting the bracket completely aside so you don't have to deal with the wire and bracket while wrestling with batteries.
  2. Mendel Leisk
    42,343
    Leave the hood popped, all door's closed, and fob away from the car: it'll be very close to nil load. I did a load test under those conditions, it was infinitesimal. In short, you don't really need to remove the battery from car to check it's voltage.
