Check Hybrid System after 12 volt battery replacement
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by djspriusc15, Feb 24, 2021.
  1. Elektroingenieur
    2,515
    3,288
    Three Touring
    Yes, assuming that warranty hasn’t yet expired (8 years or 100,000 miles) and none of its other exclusions applies.
    In fairness to the dealer, the part has several names: the Repair Manual (more info) calls it the “battery smart unit,” but Toyota’s parts catalog lists the same part as the “battery voltage sensor,” and neither of these names appears verbatim in Policy 4.25, Hybrid Vehicle System Component Warranty, in the Toyota Warranty Policy and Procedures Manual.
    Fortunately for you, the Warranty & Maintenance Guide (PDF) provided with the car sets the actual terms of the warranty, and on page 13, it lists “Battery control module (battery voltage sensor)” as one of the parts covered by the Hybrid System Warranty. If that’s not sufficient evidence for the dealer, the three-step escalation procedure is on page 5 of the Guide.
    jerrymildred likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,372
    5,404
    Pacific Northwest, USA
    Depends on the dealership... So I'm not sure. Sounds like it's the fine print that will help you or hurt you.
  3. djspriusc15
    djspriusc15 Junior Member
    2015 Prius c
    So got a call this afternoon, the dealer’s warranty administrator stated the part is not covered under the hybrid system warranty, however Toyota corporate did agreed to cover the repair. Hats off to Toyota for stepping up and doing the right thing!
    PriusCamper likes this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    No it does NOT.
    It depends on what the warranty from Toyota SAYS.
    The dealer has nothing to do with it.
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    Sounds to me like the dealer is just covering up for their initial LIE.
    :eek:
