Check Hybrid System alert after hard acceleration
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by BrianTheLion, Sep 28, 2021.
  1. BrianTheLion
    BrianTheLion New Member
    San Francisco
    I
    Hey y'all. I was driving my 2010 Prius (94,000 miles, bought used ~10,000 miles ago, with original battery) on surface streets a couple days ago and stupidly decided I needed to prove to my friend that Prius's can indeed accelerate quickly, so I stepped on the gas pedal a bit hard. Immediately the Check Hybrid System warning came on along with the master warning light, check engine light, brake system warning light, and stability control light. I still had power and needed to drive home on the highway and made it back, though the car clearly had reduced power and acceleration. It seemed like the battery was still operating based on the mpg reading I was seeing though.
    Any thoughts on what the issue could be? I checked all the fuses under the hood and they looked good (didn't get around to checking the ones under the steering wheel). Also tried turning the car on and off three times. Possibly an issue with the inverter? I haven't noticed any issues with the car or battery recently.
    I would just bring it into the shop but the dealership charges $208 just for a diagnostic and my local hybrid shop wants $175. I also see that getting my own diagnostic tool is an option but am confused if I would be able to get the codes I need with just an OBD2 scanner or if I also need a techstream knockoff to diagnose issues with the hybrid system.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Tech stream does same job as $208
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,115
    6,974
    Texas Hill Country
    You were in limp home mode because of one of several issues.
    Usually caused by a significant failure. I would go to your local hybrid shop. They will give you the best value options for the repair, which is where the real money is needed. In a 2010 there are many common hybrid problems, none of which get fixed with a diagnostic tool. For example, hybrid battery, brake booster system, electric water pumps or inverter failures.
    The one thing you can do first is take the 12v battery to an auto supply and have it load tested. If bad, replace it and then see if some of the computers work better.
  4. BrianTheLion
    San Francisco
    I
    Any suggestions for something I can buy that does the same thing as tech stream?
  5. BrianTheLion
    San Francisco
    I
    Thanks for the reply. I'm definitely expecting that I'll need to take it into the shop regardless to fix whatever failed in the car. Hoping to at least save a little money upfront by diagnosing the issue myself but I'm not sure if I'm brave enough to wade into the world of techstream and mini vci's...
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Your the second person to post this exact incident. The 1st person who did this, their inverter blew up and Toyota covered it under warranty. One of the best Prius scams on the forum!
  7. rjparker
    11,115
    6,974
    Texas Hill Country
    Kind of like saying the Brake Booster will go out if you slam on the brakes. I know my inverter failed after I parked at a restaurant. No hard acceleration, no lights until it would not Ready an hour later. The car was completely dead 90 miles from home on a Sunday evening. The Brake Booster failure at least had warning signals as the Pump ran excessively.
  8. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    If you want to get info without spending much money, get an OBDII adapter and run the Dr Prius app. It will give you most codes and tell you about hybrid battery health.
    If the 12v battery is original, it has lasted more than most, can can cause multiple warning lights to go on, should be replaced. Disconnecting and then reconnecting the 12v will probably take you out of limp mode but could clear the codes that you probably would like to know about.
  9. Mendel Leisk
    42,351
    Toyota did a software update recall, so that a sudden/hard acceleration demand is “buffered”. Post update you still get the acceleration but it happens slightly more gradually. This was to protect some soldered connections in the inverter.
    This happened in March 2014. My letter (from Toyota Canada) has the ID: SOSH-230-1A.
    For starters maybe check if yours had the update; dealership should be able to check when provided your VIN?
  10. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    I hope you've still got a good sense of humor about your prius?
    youtu.be/zI1gRqKysh4
    dig4dirt likes this.
  11. BrianTheLion
    San Francisco
    I
    Thanks for the advice everyone. I'll be taking the car into the shop this week and will update with the results. Hoping it's nothing or a blown inverter covered under warranty and that I can get back to drag racing soon.
    dig4dirt, vvillovv and Mendel Leisk like this.
  12. vvillovv
    4,337
    1,519
    NY
    If you haven't heard about Luscious Garage yet, you might want to take a peek.
    edit: Unless that is already your local garage.:cool:
  13. BrianTheLion
    San Francisco
    I
    that’s where i’m taking her!
    vvillovv likes this.
  14. BrianTheLion
    San Francisco
    I
    As suspected it was the inverter. After doing a diagnostic Luscious had me take the car to the dealership where they replaced the IPM inverter under warranty. Applicable codes were P0A94-557 DC/DC Converter Performance and P0A7A - Generator Inverter Performance.
    Glad I live in CA where the inverter warranty coverage is 15 years, not 10 like in some other states...
  15. Robhangdog
    Robhangdog New Member
    Just had the same issue with my 2010 prius w/60,000 miles.
    Hard acceleration and the check hybrid system light came on with almost no power. My mechanic suggested I take it to Toyota.
    Any advice is appreciated. I'll update on the diagnosis.
  16. bisco
    52,860
    have you had the inverter update?
  17. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    That should be covered under the extended inverter warranty.
    Lee W L likes this.
  18. Robhangdog
    I haven't had the inverter update. I hope that's the issue and it's under warranty. I have a 2010 prius with 60k miles, never had any issues other than oil changes, brakes, tires. .
    Mendel Leisk and bisco like this.
  19. Robhangdog
    I just heard back from Toyota, it's the IPM inverter, covered under warranty.
    Message to other prius owners who haven't had the update, do not put the petal to the metal.
    CR94, Lee W L and Mendel Leisk like this.
  20. Mendel Leisk
    42,351
    And get the update?
    they could have got sticky…
