Check hybrid system and brake problem
Discussion in 'Gen 3 Prius Main Forum' started by Zackbg, Mar 23, 2020.
  1. Zackbg
    Zackbg New Member
    Los Angeles
    I
    Today my check hybrid system message and yellow triangle warning light came on. About an hour before it happened I had to slam on the brakes really hard to avoid an accident.
    No codes from Autozone reader.
    I also notice now that my brake pedal will go all the way to the floor if I push it hard and sometime the traction and brake warning lights will come on when I do this. The yellow triangle and check hybrid stay on all the time.The car drives. Also battery and regen braking on the screen don't seem to be working properly. But the battery is charged somehow.
    I'm thinking that the problem is with the brake system and not the hybrid battery since I can push my brake pedal to the floor.
    Has this happened to anyone else.
    52,393
    i think you're right. do you diy?
  3. Zackbg
    Zackbg New Member
    Los Angeles
    I
    I'm going to go to dealer probably to get it diagnosed.
    I've looked at it but its hard to see anything unusual. Autozone scanner apparently doesn't read hybrid codes, only engine.
    #3 Zackbg, Mar 24, 2020
  4. Mendel Leisk
    41,906
    Do you by chance have anything connected to the OBD port?
  5. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    If your brake pedal is going all the way to the floor, I would immediately check your level in the brake fluid reservoir, and look under the car for any leaking brake fluid.
    mikey_t, Mendel Leisk and Grit like this.
  6. Zackbg
    Zackbg New Member
    Los Angeles
    I
    I don't have anything connected to the port. Brake fluid reservoir is full.
  7. Zackbg
    Zackbg New Member
    Los Angeles
    I
    Disconnected both batteries and the white cable in the fuse box. That cleared all the warnings. Drove for about forty miles around city, so far good. We'll see if it stays that way.
    mikey_t likes this.
  8. Mendel Leisk
    41,906
    Just disconnecting the 12 volt is very likely sufficient, for next time. It doesn't hurt to disconnect the big boy, but that one has been problematic for some. Mainly the final reinstall step not done, sliding it some direction.
    I had brakes acting up similarly, and it was apparently just communication problem, according to dealership. In my case it was apparently a constantly connected ScanGuage. I ceased using it about 5 years back, and no further problems.
  9. Zackbg
    Zackbg New Member
    Los Angeles
    I
    Stil running ok, no warning lights.
  10. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    Happened to me and it was wheel bearing going bad. Mechanic told me wire going to bearing and once it completely goes out it throws the codes and breaks go haywire.
