Check Hybrid System (code P03CE)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by pfile, Mar 21, 2014.
  1. pfile
    pfile Member
    319
    35
    bay area, ca
    yesterday while driving on the freeway in EV mode, my PIP (one of the first delivered to the states) flashed the "Check Hybrid System - Stop the vehicle in a safe place" message. i was near my house so i just went home. my SG2 showed code P0C3E, which is apparently an inverter overtemperature code.
    took it to the dealer this morning and they just informed me that the car needs a new inverter, but no other details… "internal fault" is what he said.
    while googling, i found this recall notice:
    Green Car Congress: Toyota recalling about 701,000 Gen 3 Prius vehicles in US over software issue in inverter assembly
    that doesn't talk specifically about the PIP and implies that it is a software problem, but goes on to say if the car is in a fault condition the inverter will be replaced. of course, it's possible that a software problem leads to hardware damage.
    the car has only about 10k miles, and about 6k of them are EV mode, so i suppose the inverter has had a workout in it's short life. regardless if toyota is going to sell a plug-in vehicle then it should be possible to run on EV 100% of the time.
    i'm a little disappointed and hope that this is a defect rather than a design flaw.
    rob
  2. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    It may just be a coincidence / bad luck. My understanding is the PiPs are not affected by the recall, but I could be wrong. There are plenty of folks on PC with a lot more EV miles than you've put on, so a major design flaw seems unlikely but it will be interesting to see what they say.
  3. mrbigh
    3,686
    699
    Long Island, NY
    Certainly, PiP's are not part of the recall.
  4. pfile
    pfile Member
    319
    35
    bay area, ca
    sorry this thread got posted twice, i will reply here as there are more replies.
    is the inverter in the PiP different than the Gen3 prius? i was under the impression they are the same, but i can see why they would be different.
    rob
  5. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    I'm not sure whether they're using different part numbers but I'm sure the software is treating them differently.
    retired4999 likes this.
  6. miscrms
    2,076
    523
    Phoenix, AZ
    My recollection is that based on part numbers the transaxles are the same, but the inverters are different. There may very well be a hardware difference in the inverter to support the greater sustained current / power capability of the PiP battery.
