Check Hybrid System Indicator
Discussion in 'Gen 3 Prius Main Forum' started by Miggsy, Jun 20, 2023.
  1. Miggsy
    Miggsy New Member
    Saint Louis
    I have a 2011 Prius. Long story short. Got into an accident, was mainly just a front bumper, it got ripped off, car was still drivable without any error lights on the dashboard. It sat for a few months ( 6 or 7 month without being driven) Finally got it towed to a carshop and they replaced the front bumper (Towed cause my 12v battery was dead). When I collected my car from the carshop the Check Hybrid System indicator is on along with the check engine light and the triangular exclamation mark. The car starts and drives, I was able to drive it home but just.
    So, engine turns on when starting the car but on the drive home, it didnt turn off once, not even at a light. The battery seems to charge when I utilize the brakes but I don't have much power in the acceleration when driving.
    Anyway, during the drive home, I realised the 12v red battery light came on and the car lost power (engine turned off), I pulled over and I was able to switch the car off and switched it back on and was able to drive, I lost power a couple of times and did the same thing again until I got home.
    Anyone have this experience and what may be causing the issue?
    2011 prius with have 115k miles
  2. SSAutomotive
    SSAutomotive Junior Member
    Stewartstown, PA
    I can say for sure the battery dying and car dying meaning it's not charging. I'd be looking at alternator output and charging system issues. Take to a knowledgeable mechanic.
    Miggsy likes this.
  3. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    Did the carshop replace the 12v? Or just jump it so it could start? A weak 12v can cause all sorts of issues.
    Miggsy likes this.
  4. Miggsy
    Miggsy New Member
    Saint Louis
    Thanks for the response, Dirk.
    I don't believe they replaced the battery. Should I start there?
  5. Brian1954
    Brian1954 Senior Member
    2,671
    1,069
    South Central PA, USA
    If you have warning lights on the dash, you have a trouble code that should be read using a scantool. The trouble code will tell you the problem with your Prius.
    Miggsy likes this.
  6. Brian1954
    2,671
    1,069
    A Prius does Not have an alternator.
    ASRDogman likes this.
  7. Miggsy
    Miggsy New Member
    Saint Louis
    But, when I drove it home, the battery did fill up, alas, depleted quickly.(I think)
  8. bisco
    52,832
    could be a bad hybrid battery from sitting so long. how many miles on her?
  9. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    Short answer is yes. Replace it and let us know what happens. Make sure you have everything reset as the Owners Manual describes. If you’re unsure how to do that, bite the bullet and have the dealership do it for you.
  10. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    Which battery are you talking about: the 12v or the Hybrid?
  11. bisco
    52,832
    the only icon showing a battery level is the hybrid battery icon
  12. SSAutomotive
    Stewartstown, PA
    Thanks for the correction, used to working on normal vehicles for so long :LOL:. I take it whatever step down transformer or system they use is responsible for that. I'll have to double back at some point. Cheers.
  13. Doug McC
    1,087
    428
    Midwest
    2022 Prius
    It was the “(I Think)” part that has me confused due to that point. The OP should be able to see it, right?
  14. bisco
    52,832
    yes, it's next to the gas gauge. and also confusing because they start with the 12 volt warning on the mfd
  15. bisco
    52,832
    and the car restarted after turning off and on, so 12v working?
  16. Miggsy
    Miggsy New Member
    Saint Louis
    The hybrid battery on the display filled up while driving.
    I know, I'm confused, too. So, the 12v red light turned on while I was driving and a few moments later, the engine turned off but I still had electrical power in the car.
    But I know, the 12v battery had to be jumped when they towed it to the shop to get my bumper fixed.
    115k
    #16 Miggsy, Jun 22, 2023
  17. SSAutomotive
    Stewartstown, PA
    Re-reading this I'd consider replacing the 12V battery, and while you've got it apart, checking charge voltage to said battery. If the problem persists I'd be considering chewed wiring from a cheese eating friend, possibly to ECM main or similar.
    Doug McC likes this.
  18. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    Is your 12v an original? I'll have to look when I get home, but I replaced the original 12v on my car just this last year and I have a 2011 also. I didn't use the same size battery as stock, but one slightly larger if I remember right.
