Check Hybrid System Low engine coolant?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Nov 19, 2022.
  1. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    2010 won't start I get the check hybrid system disconnected the battery and recoonnected did not correct the problem
    The engine coolant is low and the battery coolant is a little low.
    Could that have anything to do with it?
    Thanks
  2. Tombukt2
    Tombukt2 Senior Member
    13,765
    2,491
    Durham NC
    Probably not to be honest about it need to scan it for the codes quick things come to mind like inverter pumps but need to check your codes see if there's any electrical issues
  3. Mendel Leisk
    42,205
    "battery coolant" is this one?
    Grit likes this.
  4. Taxi/Limo
    526
    107
    I noticed my under the hood fuse box had debris in it which I have never seem before because it is covered
    I thing some rodents got in there to get out of the cold
    I wonder if that is what the problem is?
    How could they get in there ? it is covered
  5. Taxi/Limo
    526
    107
    Yes and it is a little low
    The engine coolant far left in engine compartment
    Is also low
  6. Taxi/Limo
    526
    107
    How do you scan for codes?
  7. Taxi/Limo
    526
    107
    I think it's the brake system
    I have full brake fluid actually it's overful
    The ABS light is on in yellow on the dash and I have no resistance when I push the brakes pedal down (engine off)
    Could it be as simple as a blown fuse ?
  8. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I don’t think it’s any of those you mention that is causing it to not start. I would take out the excess brake fluid immediately with a turkey baster or something similar. (Don’t use it for food after). Excess brake fluid will heat up and expand. This may cause your front driver side brake to engage by itself and heat up that wheel/area. I know from experience, not in a Toyota though. Top off the low coolant if it’s not excessively low then move on. If it’s really low then need to investigate why.
    Rats! They’re known to eat through wiring harnesses. Gotta look for any damage to the wiring…
    iPhone ?
  9. ChapmanF
    18,897
    As soon as you can, please report the brake system trouble codes here. That will give us something to go on to understand the issues.
  10. Taxi/Limo
    526
    107
    I can do that I will need a scanner first
  11. ChapmanF
    18,897
    You can get brake system codes without a scanner.
    jzchen likes this.
  12. Taxi/Limo
    526
    107
    How?
  13. ChapmanF
    18,897
  14. Taxi/Limo
    526
    107
  15. ChapmanF
    18,897
    You don't have flashes to count until you ask for them, which most of the search hits on that topic explain how to do.
  16. Taxi/Limo
    526
    107
    Okay
