Check Hybrid System - No shift to drive/Reverse - ICE not running
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by J0hnny, Oct 26, 2021.
  1. J0hnny
    J0hnny Junior Member
    Bay Area
    I was driving on the freeway and suddenly the car came to a crawl. It didnt die but it was going really slow and the dash was saying "check hybrid system stop vehicle in safe place". So I pulled over near an off ramp and turned the car off. Turned it back on and same thing. I noticed the Internal combustion engine wasnt running so it was just driving on battery. I drove it about 100 yards down the off ramp and into a grocery store parking lot and called a tow truck and towed it home.
    The next morning I turned it on and the car would not shift into drive or reverse. I checked the 12v battery and it was 11.3v on the diagnostic page screen and with my hand held. The 12v was the original that came with the car.. so it was due for a change. I ended up buying a new 12v battery but no joy. Car still wont shift into gear and the dash is lit up with all sorts of lights including the CEL and the check hybrid system message.
    I have 2 bars in gas so I dont think I ran out of fuel.. I tried to use a cheap CEL checker but it said no codes. Any Ideas whats going on? Ive uploaded a picture of the dash with the lights and the cheap obdII scanner I tried. Car has 120k.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Your traction battery drained and needs to be recharged
  3. J0hnny
    Bay Area
    Hey thanks for the reply! Forgive my ignorance..does this mean rip hybrid battery? I was hoping this would be something less serious.. If so I hope the battery is under warranty still? Someone mentioned to me that Toyota warranty's the hybrid battery for 10yrs/150k and im at 120k and a couple months shy of 10yrs.
    52,855
    check the inverter pump
  5. bisco
    52,855
    have you done the ipm recall?
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    NO, not really.
    More likely that the traction battery has failed.
    Recharging is NOT recommended.
  7. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    With being low on fuel only having two squares I would add some fuel to it. This is not what is causing the vehicle to not start but may have been the initial start of the problems. Sounds like you most likely drove on your traction battery and now it’s dead. Same thing happened to me I had to add fuel even though it was registering a quarter tank.
  8. J0hnny
    Bay Area
    Ok Ill look into that.
    No I havent.. I saw that yesterday when I entered my vin on the toyota website .. Thats the E0E or something like that I think yeah?
    Looks like Im gonna have to find a gas tank. I would have thought to bars was enough to be ok per say.. Is there a chance that my gas meter is bad or are these things not very accurate on these cars?
  9. bisco
    52,855
    the gen 3's are pretty accurate, but it's always worth putting 3 gallons in when it won't start.
    you need a tank with a nozzlw narrow enough to go through the valve door
  10. J0hnny
    Bay Area
    Hey Bisco, I got a gas can today and threw about two gallons in it bringing me to about 4 bars but its not trying to start or shift. It just goes into neutral and that's about it. Now that I think about it when I installed the new 12v battery... on first start the Internal combustion engine did come on and it did shift into gear but the check hybrid system message was still on the screen accompanied with all the lights on the dash being on so I just turned it off. Further attempts to turn on the car have since failed. Should I unplug the 12v battery and let it sit for a bit before trying to start it again or was that a coincidence?
    I ordered a mini vci cable and a Bluetooth obdII scanner and they should be here late tomorrow night. I'm preparing an older laptop and with a 32bit os and Im crossing my fingers that I get answers but Ive never used Techstream before so we shall see. In the meantime maybe I will add one more gallon in the morning and see what that does.
  11. bisco
    52,855
    it's certainly worth a try, and you can also try pressing the go button 3 times with foot on the brake, and also holding it in for 10 or 20 seconds with foot on the brake.
    in the end, you might need to have the trouble codes read.
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    You should make sure that the new battery is fully charged and not defective.
    Yes, sometimes new ones are bad.
    And very often new ones come with a half charge or less.
    The main connections need to be checked too.
    A multi-meter can be had for as little as $8.
  13. J0hnny
    Bay Area
    I gave that a shot with no luck.. I tried both 10 and 20 seconds separately..
    I purchased a Panlong obdII bluetooth device but I couldnt get it to connect. Just wouldnt show up in blue tooth devices in dr prius. When I plug it in into the port on the car a lil red light comes on and thats it. I thought I could use it read the codes but no joy.. I will try again later and see if I can get it to connect.
    and to add to my luck the vendor on amazon who I purchased the mini vci cable from sent me a link to the Techstream software on a filesharing website and included some cryptic instructions. Im going to make an Image of my os installation before moving forward. Cant believe its this hard to get fault codes on a prius.
    Man Im in denial right now.. How did you know? The new 12v battery reads 11.7 with a multimeter directly attached to the battery. The prius diagnostic screen says its 11.6v. This reading should be 12v and above if im not mistaken on a new battery yeah?
    (If i didnt say it before, thanks to everyone in this thread who is trying to help me with this)
  14. bisco
    52,855
    there's no exact measurement, but 11.7 is low. you can take it to an auto parts store for a free load test.
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    About 60 years of experience.
    And Electronics training helps too. :)
    A new fully charged AGM battery with no load should be at least 12.8.......and those tenths are important.
    While that might not be the whole problem, you need to sort that out first before you go looking for something else.
  16. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    It's not hard at all. Rather than jump through all the hoops of Techstream (which is the ultimate), just get a decent OBDII reader such as the one Carista sells or, better yet, the OBDLink LX. (I have at couple of the cheap knockoff ones that worked about as well as yours did laying around. Waste of money.)
    Then use Dr. Prius or one of the many other phone apps to read the codes. That'll get you pointed in the right direction. If it turns out to be something like a P0A80, then Techstream will give you more details.
  17. J0hnny
    Bay Area
    So it turns out Autozone did give me a bad battery but when I went to return it they didnt have any there and in any store in a 50 mile radius! I ended up having to return it and I went to Orielly and bought a battery there. I told them what happened and they actually gave me a discount and had me walk in the back of the store with my volt meter to compare results before I left the store and it was a 12.5 on the new battery they sold me. Unfortunate that it didnt solve my problems but I did manage to get a fault code after getting the obdII reader to pair finally. P0A1A, P0A94P0A94 which I think is an inverter. (Attached screenshot) I posted what happened at the dealer below in the reply to jerrymildred.
    Man I wish I could download your experience right now matrix style! haha..
    Thanks for chiming in.. I did exactly that and got a code, Initially it was a failure on my end in terms of pairing the obdII.. I got the panlong obdII bluetooth reader and used dr prius like you said and I got a P0A1A, P0A94P0A94.
    When I looked to see if there was a recall it looked like it should be covered by the JOV reference ID. I typed my vin into the toyota website and it was listed as something that need to be done.
    I ended up talking it to the dealership today and they said they would get back to me by end of day or tomorrow and when I mention the inverter and the recall he said the recall was just for a "software update" and tried to sell me some 120k mileage service @$1197 on top of what ever is wrong with my car! Ive attached the screenshot from the toyota website that states they would fix it if there was an inverter failure related to the JOV recall but im not sure how to prove this was related to that since all I know is that I got the inverter fault code and the car stalled on me on the freeway. (P0A1A, P0A94P0A94)
    Screenshot 2021-11-04 at 13-21-10 Lookup Safety Recalls Service Campaigns.png
  18. sam spade 2
    7,035
    2,804
    2017 Prius c
    While it is highly unlikely that is the root cause of your remaining problem,
    12.5 is NOT indicative of a fully charged battery.
    Sometime soon, you really should "top it up" because the car might take a LONG time to do it.
  19. J0hnny
    Bay Area
    Im going to look into a battery charger for the 12 volt so that I can have something in house and I will use that to top off the battery when needed as sometimes I dont drive the car for a week +.
    On a good note! I just got a call from the service manager at the dealership where I had my car towed and he said it was the ICM module and that it was covered by an extended warranty! He said the part will not come in until Thursday or Friday tho so I don't imagine the car will be done until late next week or the week after. I guess supply chain issues are front and center.
    Anyway.. Thank you very much for your help with this. Its much appreciated! A special shot out and thank you to bisco, jerrymildred, 2010moneypit? and everyone else who tried to help me put a finger on the problem.
    To everyone else reading this in the future, if you get a P0A1A and "all the lights" on the dash come on including the check hybrid warning system then check the Inverter Control Module.
    2010moneypit? and jerrymildred like this.
  20. ChapmanF
    19,025
    That's good news.
    P0A1A says "generator control module" in its fortune cookie, which is also known as the MG ECU. It is one of the components inside the inverter assembly, and it is covered under the warranty enhancement program ZE3, which applies when one or more of DTCs P0A94, P324E, P3004, and/or P0A1A are present.
    It is hard to make any judgment based on what dash lights are on. Most codes detected by any given ECU are going to light the same dash lights. The key to determining whether this support applies to you is just to not pass go, not collect two hundred dollars, and go directly to finding out what codes you have.
