Check Hybrid System - No sub codes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rkhaler, Jun 29, 2022.
  1. rkhaler
    rkhaler New Member
    Arizona
    I have a 2011 Prius with 250K. Bought it used about 1 month ago. I put just over 1,000 miles on before having issues. I drove to costco, filled up the gas tank, parked it and went to shop. Came back out and within 10 minutes on the freeway I got the triangle of death, VSC, and (!) on the dash with "check hybrid system". Battery is charging just fine, held charge ok. AC compressor was recently replaced and the hybrid battery was replaced (not OE but from Greentec auto as refurbished) 2 months ago by previous owner.
    When this alert popped up I took it back to them to trouble shoot and/or warranty the battery. They put a new battery in, cleared the code and sent me on my way. "Check hybrid system" came back on within a few minutes. I don't have tech stream but they did so I left it with them to pull the sub codes. They had the car for almost 2 weeks and could not get any sub codes to pop. Only P0AA6 526. They swapped inverters even with no luck. The car drives fine, at least it seems that way. I was getting around 50mpg during the 1,000 miles I drove it.
    They tested MG1 and MG2 with a megger and all values were said within range. They swapped inverter and that didn't work. They tried 3 total batteries and that didn't work. The 12V battery is fine. Finally, they decided to unplug the AC compressor and I got a call today they drove over 50 miles with it and left it on for 30 minutes and no warning lights. So I went and picked it up and was driving home with AC compressor unplugged and all seemed well. Thought I won and would need to just swap compressors but then after about 20 miles on the highway the same warning lights and "check hybrid system" popped up.
    Any idea what could cause this and why TechStream will not show a sub code to isolate the issue? Transmission fluid was flushed about 350 miles before this happened with WS ATF, replaced struts, shocks, lower control arms, balljoint, stabilizers, etc as the car had 250K on it. Honestly seems to drive fine still and I can't figure out where to go from here. I have searched the forums for something similar to this and can't find anything as everyone has a sub code to go off of.
    51,154
    click on the attachment in post #24 in this thread:
    page-2
    it looks like you have some electrical troubleshooting to do.
    read post #35
  3. rkhaler
    rkhaler New Member
    Arizona
    I appreciate it. I’ve spent some time diving into this. I’m just struggling to get someone to pull the specific INF sub code (612,611,613, etc). Sounds like what you’re suggesting is to manually start testing for resistance?
    I am going to attempt one more shop that’s familiar with hybrids (they service a lot do the ride share Prius’s where I live). I’m not mechanically illiterate but I’m not a full blown mechanic. Bring in electric systems I I’m venturing into uncharted territory.
    I cleared the code last night and drove 30 miles to work today. The code came on after about 25 miles (usually it’s immediate) and this time it was just the triangle of death and no VSC or (!). Being the warning light came on after swapping hybrid battery, inverter, and disconnecting the AC compressor I am a little worried it’s MG1 or MG2. But maybe it’s just a simple short somewhere else in the system.
    Anyways, I’m gonna drop it off today and hopefully get a confirmed source of the issue. Good news is salvaged items like transaxles and inverters aren’t too costly. Big question is where to draw the line on a gen3 that’s a little rough around the edges and is approaching 300k. Still getting 50mpg and it’s driving just fine otherwise. Cost of cars right now is insane so I’d rather invest a little and recoup in ROI down the line.
  4. Tombukt2
    Tombukt2 Senior Member
    12,211
    2,153
    Durham NC
    Is this the check hybrid system park on level ground blah blah blah something as simple as a door switch not working can cause that I believe if you leave the door open or unlatched you will get that I do believe I do in my Jen too I'm not positive what happens in the three
  5. rkhaler
    rkhaler New Member
    Arizona
    Yup. I have read that almost anything can cause this issue. Everyone I talk to keeps saying it's probably the Greentec Auto battery but I am unsure because they replaced it immediately when I brought it back, then again swapped it. So 3 separate batteries still caused it. They offer 48 month unlimited mileage warranties on them so I would think maybe they aren't all complete junk compared to OE.
    But yeah, it has happened in cool weather, hot weather, on the highway, parked level, parked in the driveway, etc. Sometimes it lights up within 3 minutes on the car, sometimes it doesn't for 30 minutes. Now it's only only displaying the triangle and nothing else where before it had VSC, and (!). I have a feeling I am about to be very well versed in hybrid systems lol...
  6. ChapmanF
    17,343
    That's what you normally see when the car has first noticed that there's a voltage leak. It sets the 526 as a note-to-self so the next time it powers up, it will see the 526 code it already set, and do more extensive testing to pin down where the leak is, and after that you will have both the 526 and the other, more specific code.
    One way people sometimes defeat that is if they keep reading the P0AA6 526 and clearing it, so the car never performs the further-testing step. So it will keep coming back P0AA6 526 but never show the more specific code. The P0AA6 526 has to be left there, not cleared, so on a future power-up the car will make diagnostic progress.
    There may be a few situations where the car's further-testing methods are inconclusive and so it just doesn't set the more specific code. I don't think that's very common, but if you're sure you've given it multiple power cycles, without clearing the 526, and it still hasn't come up with a specific one, then just following the 526-only steps with a megger may be the only way forward.
  7. bisco
    51,154
    take a good look at the a/c plug they disconnected, maybe the fact that the lights didn't come on for awhile is related.
    you're looking for corrosion, bad pins, chewed wires, etc. it could be in the hv wiring harness to the battery, or even in the tranny
  8. rkhaler
    rkhaler New Member
    Arizona
    I definitely has cycled through multiple times. There was point there was quite a few miles put on after multiple start ups too. The car also never goes into limp mode. I just dropped it off at a shop who knows more than I would. Hopefully it's just something minor but with my luck it will end up being a transaxle issue lol.
    I did check all of that on the compressor side and it looked ok. The car has also never left Arizona so there is little issue with corrosion. Overall, for how many miles are on it, it's pretty clean.
  9. Tombukt2
    12,211
    2,153
    Durham NC
    Yes most of these I see in the southeast can be dirty but they're together and many the maintenance is up today and they're driving well so they kind of hold their value when there's a crisis with fuel
  10. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    o_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_O
  11. rkhaler
    rkhaler New Member
    Arizona
    Still no sub codes to be thrown and no one can figure out why. I have had it with a reputable shop in the valley who specializes in toyota/lexus hybrids. They actually do lots of the prius fleet vehicles too. Lots of miles put on the car with no luck beyond P0AA6 526 - shop seems stumped. Next step is connector/terminals themselves. Everything else seems to test out ok. Inverter has been swapped, AC compressor swapped, multiple hybrid batteries (although refurbished - but what's the chance of 3 in a row being bad?). I know the refurbished batteries get a bad reputation so maybe it could be the issue but the cells have been tested.
    At this point, I might just drive it into the ground until it stops driving. Drivability is not affected, the hybrid battery charges/discharges fine, the AC is ice cold... I just can't go into EV mode or use cruise control etc.
  12. Wallace Santana
    Wallace Santana New Member
    Las Vegas
    Hi , I have the same problem with my Prius , did you fix your car ?
  13. ChapmanF
    17,343
    Often "the same problem" posts aren't really about the same problem. The latest poster in this thread had a P0AA6 code with the 526 INF code, but apparently never latching any of the other four specific INF codes.
    Is that an exact description of what your car is also doing?
    If not, it will be more fruitful just to describe in detail the problem and the trouble codes your car has.
  14. rkhaler
    rkhaler New Member
    Arizona
    Sorry I have been MIA. Life took over. But I do have an update.
    The culprit was the refurbished Greentec Auto battery (all 3 of them). I finally just bit the bullet and went OE. I’ve put over 2000 miles on it the last 2 weeks and it’s been perfect.
    Buy once cry once I suppose. Both shops said they no longer mess with refurbished 3rd party batteries because this happens all too often. I know many people have good luck with them but I went through 3 in 3 weeks and all 3 seem to have been problematic.
    Noahdoge, bisco and ASRDogman like this.
  15. bisco
    51,154
    that's great! i heard oem's are in short supply, how long did it take to get one?
  16. rkhaler
    rkhaler New Member
    Arizona
    I was not aware they are in short supply right now. It was ordered/received same day. I live in Arizona. Was not the cheapest of fixes but at least it's done and over with.
  17. rjparker
    rjparker Tu Humilde Sirviente
    9,596
    5,893
    Texas Hill Country
    Famous last words
    This thread should be required reading for the used battery shoppers
  18. rkhaler
    rkhaler New Member
    Arizona
    lol right? I bought the car used and the previous owner 2 months prior spent 1600 dollars on this 3rd party battery. I tried so hard to make their warranty work for me. Just not reliable at all and it gets to a point where time is worth more than money.
    Do it right once and move on.
    ASRDogman likes this.
  19. ASRDogman
    ASRDogman Senior Member
    7,241
    3,779
    You should tell the original owner to get there money back.
    Or you get it back. They don't work. And check on a lemon law for your state.
    In Florida, it if fails 3 times, you get your money back. I don't remember all the details about how.
    But $2000 plus is a lot of money, at least to me.
  20. Tombukt2
    12,211
    2,153
    Durham NC
    Yep real batteries make real differences many times That's why I figured for my '09 I would just bite the bullet I need that car on the road. The 13 right after I got the engine in it and the battery was throwing codes left and right I'd met up with the guy at Dr Prius in Virginia and he did me real right for $600 so I don't use the 13 that much it's a ladies car that sits in the driveway more than anything. But my '09 is running a hundred miles a day sometimes double that and there has been no trouble since the battery went in 47.8 is normal mileage The 50 business will show up every so often but we don't worry with that.
