P0AA6, detail 526, and 612
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 98redkick, Jun 25, 2018.
  1. Cody26
    Cody26 Junior Member
    86
    Raleigh, North Carolina
    Could you give me some guidance on how to check which one is at fault?
  2. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    What do you mean by which is at fault? Do you mean which one of the 4 INF codes 612 -615?
    If so, you use Techstream to look in the freeze frame data and it will tell you.
  3. Cody26
    86
    Thanks for your answer. Could you have a look at what I got for this problem
  4. dolj
    dolj Senior Member
    8,646
    4,397
    The first image shows that you have INF codes 526 and 612 which points you to a HV leak in your HV battery area (purple shaded area in the image below).
    Attached is the inspection procedure for P0AA6. Go to the section which details what to do for INF 612.
    MAX2, Chris Blanchard and Raytheeagle like this.
  5. Cody26
    86
    Thank you, sir! My prius is 2007 probably it is ok to have 2006. Also, where did you get the attached file?
  6. ChapmanF
    19,016
    You've got 526 and 612, right there on the first screenshot you attached (the freeze frame). Look at the "detail code" rows.
    The 526 is the code it sets the first time it notices the leak, and hasn't noticed where it's coming from. That's a note to itself to pay extra attention the next time you start the car, and it goes "aha! caught it in the battery!" and sets the 612 code.
    That code means the voltage leak is somewhere among the components back inside the battery case. Battery goop leaking from a module to the case, the system main relays, the precharge resistor, the battery ECU, the cables between them ... almost all stuff back there inside that case. The repair manual directs you (with a 612) to steps 5 through 17 of a workup section (that's the 2006 edition, anyway) to pin down which of those things it is.
    Some other leak codes can be worse news. With this code, you've got at least a sporting chance the leak is caused by something you can just clean up.
    -Chap
    dolj likes this.
  7. dolj
    dolj Senior Member
    8,646
    4,397
    Yes the information should be ok for the 2007 and both files come from the 2006 repair manual.
    If you want the full repair manual do a search in the Gen 2 forums and look for a post where a member gives a download link for the manual.
  8. Cody26
    86
    Thanks for the input. Now I have concerns about whether I have to do balancing of voltages for modules because I will be disconnecting the hv battery and therefore might have to charge/recharge process as I detach the hv battery in order to find out what was the cause for the codes 526 and 612.
  9. dolj
    dolj Senior Member
    8,646
    4,397
    You don’t necessarily need to balance each module just because you have disassembled the battery. You may need to, and then again you may not need to.
    You haven’t provided any information for us to say one way or the other.
    If your battery was otherwise working fine, I’d just clean up the cause of the HV leakage and reassemble it.
    If you have damaged modules that are leaking, they will need to be replaced and that could get tricky, but you need to match a replacement module to your existing and you may need to also balance it. For that you will need at least one RC charger and a method to discharge the module.
    Cody26 likes this.
  10. euroconic
    euroconic Junior Member
    Minsk, Belarus
    Have the same error codes on my Prius V 2015 60k mileage
  11. ceccorp
    ceccorp Junior Member
    World
    Does anyone have pictures or a diagram of all of these Hybrid Battery Voltage System connections?
    I started taking things apart and have already found that the previous owner forgot to plug in the cooling fan. So I am thinking it's a good idea to check all the connections before tearing apart the battery.
  12. Tombukt2
    Tombukt2 Senior Member
    13,855
    2,516
    Durham NC
    My 09 codes with batt fan unplugged . If I do it right now car won't go in ready state I thot this was weird so I get out Plug fan up. HV battery bad fan on all time . Batt never hot I figured un plug fan see if any heat held in batt. Car won't run till I plug up batt fan.Doh
    SM-A715F ?
  13. ChapmanF
    19,016
    Our wiki page on where to find that information is here.
  14. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I only have P0aa6 with 526 and no other sub codes. Where should i look in to. this is 07 prius and 14 battery blocks were reading 15.8 plus or minus but roughly same.
    The car doesnt go in ready mode.
  15. ChapmanF
    19,016
    When you see only inf code 526, that means the car has only first detected the leakage, and has not yet been able to refine its location.
    The usual thing to do is to power the car off, and power it back on again (do not clear the P0AA6 code). When the car next powers on and sees there is a saved P0AA6-526, it takes the extra steps needed to isolate the leak to one of four areas, and after that you should also have one of the INF codes 611, 612, 613, or 614.
    If the car is unable to set a more specific code when powered on a couple more times, then you just have to go through the repair manual troubleshooting steps for all of the possible areas. But ordinarily, you would just give the car its chance to set the more specific code. Then you can focus your diagnosis efforts in that area.
  16. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    The car doesn’t start. I have only tried removing the hybrid battery safety plug and waited 3 minutes before putting it back in. But still nothing.
  17. ChapmanF
    19,016
    We don't need starting. Only going to IG-ON state. The same state it was in for reading the P0AA6-526. Needs to go there again to produce the second, more specific INF code.
  18. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
    I got these codes when one terminal stud broke and I tried to use wire around it to make connection to the harness. This method has worked in the past, I think I should've added some solder but ended up just swapping the cell for another and the error went away. No leaking in my situation.
  19. Tombukt2
    13,855
    2,516
    Durham NC
    You swapped the module You can't swap cells you can't open a prismatic module up to get at the six cells and if you do it's ruined.
  20. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    who says I have prismatic module? I didn't...
