Check Hybrid System P0A1A Info/Sub Code 151 659
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by kilimar, Feb 25, 2022.
  1. kilimar
    kilimar Junior Member
    47
    This is jus an FYI post. --- I had this long detailed post typed out and boom, something happened wiped it out so, I'm just going to post a photo of what they said what they did. If I feel up to it, I may come back and retype everything that I had. recall.png IMG_20220225_191726283.jpg
    Interestingly enough the $$ they charged Toyota like > $3500 (they showed me the invoice) -- I think the screen capture above was just an estimate.
    Reference Links:
    https://static.nhtsa.gov/odi/tsbs/2018/MC-10145758-9999.pdf
    https://static.nhtsa.gov/odi/tsbs/2016/MC-10140583-9999.pdf
    DTC P0A1A-151 Generator Control Module | 2014 Prius C DIY Repair Guide
    https://www.toyoheadquarters.com/threads/2010-2014-toyota-prius-intelligent-power-module-ipm-warranty-extension-ze3.439
    #1 kilimar, Feb 25, 2022
    49,542
    is this a prime or 2010?
    sounds like a dealer screw up, not unusual
  3. kilimar
    47
    Sorry, I didn't state it; it's a hybrid, not a Prime. I asked them about the 'needed services':
    • Throttle body - they said that it's in the manual and occurs at like 30k, or some nonsense like that. $85
    • Spark Plugs. I did them about 2000 miles ago.. They said, oh, they recommend based on mileage and Toyota service history; so no opening one and checking. $225
    • The Brake service did have measurements, 3mm fronts, 7mm backs. They said that they take the wheel off to check... Not sure that I trust them that they actually did that.... $250 (just the fronts)
    • Tires - 4mm-6mm, yeah, they need to replace in the near future. $688
    • Wipers - I put new ones in like 6 months ago and they look fine. $40
    So yeah...
    49,542
    unfortunately, there are many unscrupulous dealers out there, good that you were forewarned and forearmed (y)
