Check Hybrid System P0AA6
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, Sep 27, 2017.
  1. JC91006
    16,936
    8,647
    Amazing! You got skills
    #21 JC91006, Oct 10, 2017
  2. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    Compressor prices are super crazy.
    Screen Shot 2017-10-11 at 6.17.37 PM.png Screen Shot 2017-10-11 at 6.14.38 PM.png
  3. Mendel Leisk
    42,358
    Folks, this should be a wake-up call. Just lie on the ground in front of yours, and with a strong light, take a look through the grill. If needed, a wet-dry vac with thin hose extension could reach through the grill, fish stuff out.
    Raytheeagle likes this.
  4. danlatu
    533
    1,367
    maryland
    This is a pic of the radiator, it is behind the condenser. This prius has 302k miles on it so there is a little more wear and tear. All the sound insulation fell off the wheel wells.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I put a bra on the front of our Prius very early on to minimize rock chips and damage to the radiator;).
    I would take a pic, but the air quality is very poor this evening due to the Atlas Fire:(.
    No leaves get past the bra though(y).
  6. Mendel Leisk
    42,358
    Pretty tough down there right now eh? I was listening to an interview on CBC radio, yesterday morning: he and his family just got out with the clothes on their backs. Next to no warning. Terrible.
  7. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    It's bad:(. On the drive home tonight, one of the refineries that is ~1/4 mile off of the freeway couldn't be seen due to the thick smoke:eek:.
    Then approaching the I-80/680 junction, all of green valley could not be seen. The winds will pick up this evening (10-20 mph) and be out of the north. The terrain in the Green valley highlands is mountainous and inaccessible to the fire crews. Only 3% containment on the atlas fire and over 42,000 acres burned.
    I've got the Prius and RX packed and ready to go just in case (y).
    m.wynn and Mendel Leisk like this.
  8. Glyn
    Glyn New Member
    Germany
    Active
    I have a similar problem. Prius model 2010 ZVW30
    One morning, about a week ago, I suddenly got an orange triangle and "Check Hybrid System" message.
    I tried resetting by removing negative 12v, checked the orange switch on the HV battery, replaced the 12v battery with a new one, checked all fuses and looked for obvious possible causes. All to no avail.
    Dealer says it's code P0AA6 with no sub-codes.
    At first they couldn't find the fault. After a more in depth search they came to the conclusion that the inverter is at fault and needs to be replaced at a cost of €3000 plus labour. Wonderful!
    However, I'm not convinced.
    I'd like to have a look myself, specifically the short wave values mentioned by Travis Decker.
    I'm hoping for advise as to what gear to buy, which software version (will the free Lite version be okay?) and which obdII connector.
    So, the car drives fine and has done for over a week now, no increase in fuel consumption.
    After a few minutes of driving the display, showing the flow of charge stops showing the little animated arrows, and it is no longer possible to chose EV, eco or Sport Mode, these lights also go out.
    I'd really appreciate any help or hints, as to what the causes may be or regarding test equipment.
    Please bear in mind that I'm based in Germany.
    Cheers.
  9. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Well, please do put is in the picture, when the problem is solved.
    I for one, wanna learn!!!!!?
    Andyprius1 likes this.
  10. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Please what conclusions did you make to arrive at that "short of a thing"?
    Is there any relationship?
  11. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Great photos and Great fix !
  12. Andyprius1
    2,327
    859
    Cool CA
    First picture on Post 12, the HV plug shorted out, probably from too much water.
    I congratulate you on wanting to learn, stick with us.
  13. danlatu
    533
    1,367
    maryland
    Mini vci is what i used and the techstream software is included.
  14. danlatu
    533
    1,367
    maryland
  15. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Yeah, pretty nice comment:D
