Check Hybrid System Problem
Discussion in 'Gen 3 Prius Technical Discussion' started by Ahmad Hommos, Feb 9, 2019.
  1. Ahmad Hommos
    Ahmad Hommos New Member
    Jordan
    Dear All,
    Kindly My 2010 Prius gives Check Hybrid System code was Power Train P0A80.
    Please advice.
    Thanks,
    Ahmad
      File size:
      349.4 KB
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Need to troubleshoot HV battery; attached picture indicates cell voltages are out of range compared others. Common fixes for P0A80- buss bar point of contact deoxidation, re-balancing battery pack, then replacing individual cells and replacing entire hv pack.
    Raytheeagle and bisco like this.
    52,820
    check the intake grille and clean the cooling fan
  4. Ahmad Hommos
    Jordan
    Thanks guys for your fast response, Okay I will do all steps.
    Thanks again.
    Ahmad
