Check Hybrid System. Stop the vehicle in a safe place
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cipsaz187, Apr 16, 2016.
  1. cipsaz187
    cipsaz187 Member
    147
    42
    Changed the cabin and engine air filter yesterday. Today couple mins out of the driveway I am getting this error.. Seems weird. The screen doesn't show the battery is being charged or discharged. Started driving with 2 bars left, went to green three and the error.. The vehicle operates just fine. Shuts off the engine after the warm up. Everything works, just this error. Battery over 12.8V, 61k miles on her. Any ideas?
    51,155
    12.8 with everything off, after a few hours?
  3. cipsaz187
    cipsaz187 Member
    147
    42
    12.8V in the morning. Just drove around to charge the battery and it does charge up, but it doesn't show being charged. Only the green bars goes up as the battery charges. I will go to the dealer on Monday, just scratching my head if I should get it towed or not, probably not. Still weird if you ask me, but I guess it does happen.
    51,155
    probably something in the display equipment, but once you eliminate the 12v as the problem, i'm out of my element. all the best!(y)
  5. cipsaz187
    cipsaz187 Member
    147
    42
    How accurate is the voltmeter? Still charging the battery overnight. Will see if it makes a difference.
  6. bisco
    51,155
    a digital voltmeter is as accurate as you can get.
  7. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    Are we possibly confusing the "12-volt" battery (the one that showed 12.8V) with the high-voltage traction battery (whose state-of-charge is shown by those green bars on the dash)?
  8. cipsaz187
    cipsaz187 Member
    147
    42
    An update..
    The dealer has inspected the vehicle and came up with a Rodent Damage. What happened is that the the squirrel chewed some cooling wire. I suspected this issue since my dad's washer fluid reservoir was also chewed up. Anyways, the issue is complicated. Requires to drop the whole sub frame. They came up with 8 hours of work and over $1k bill. Dealing with insurance company now. Frustrating to be honest.
  9. bisco
    51,155
    wow, that's brutal. dang squirrels.:mad: all the best.(y)
  10. cipsaz187
    cipsaz187 Member
    147
    42
    I got the car back. Had to eat half the cost since my deductible is $500.. Frustrating. They've been done with the car yesterday or even earlier since its been sitting outside and rusty rotors caught my eye. The 4 days of work is probably a dealer's bull. Now not even sure if that sub frame has been lowered. I guess I will find out when I change the oil later this month. Probably could have done the work my self since they didn't replace anything, just repaired the damn wire....
