Check hybrid system stop vehicle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ahlvin, Mar 18, 2018.
  1. Henry.norcross.ii
    Henry.norcross.ii New Member
    A possible cause for the Check Hybrid System error is if there is an issue with your cooling system. Check to see if the radiator cooling fans are working, check your antifreeze level to see if it's low, and check your inverter coolant level. If there's an issue with any of those they can affect the hybrid system.
    52,819
    and check the hybrid cooling fan
    edit; dang, o/p already mentioned that :mad:
