Check Hybrid System warning after installing BluLogic
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bensmail, Feb 6, 2010.
  1. bensmail
    bensmail New Member
    16
    Maine
    I just installed BluLogic and now I have a Check Hybrid System warning.
    I'm guessing it's because I wanted to test the installation before putting everything back together and when I turned on the car it was giving me a warning that the park button was disconnected. But that's just a guess..... I left the headlights on a long time. Do you get that warning with a low battery?
    I tried idling the car for a few minutes and backed out of the garage but the message keeps popping back up along with the yellow triangle "!"
    Anyone know for sure if starting the car with the park switch disconnected will do this and will it clear on it's own?
    Thanks
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Assuming nothing else is wrong, after the third full power on-off sequences, the error should disappear.
  3. Clmchris
    Clmchris New Member
    Did that fix it?
  4. bensmail
    bensmail New Member
    16
    Maine
    Yes, the message went away. It was caused by starting the car with the buttons disconnected.
  5. RadioZero
    RadioZero Member
    154
    59
    Orlando
    2018 Prius
    had the same problem after installing a iPod adapter harness. pulled the dash apart and double checked all plugs including the ones around the shifter (just in case) and the warning went away.
