"Check Hybrid System" Warning Screen
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Crabtech, Aug 4, 2012.
  1. PriusInParadise
    180
    91
    Hawaii
    The evap pressure sensor is part of the Evap Charcoal canister. It is mounted under the car, rearward of the fuel tank, toward the left. There is a harness connector relating to this sensor. It is connector AM2, a white 18-way connector mounted at the left kick panel. There should be two connectors above and forward of the main group of 5 or so connectors at the base of the left kick panel. AM2 is the lower of the two in the upper group. See the harness routing view attached.
  2. Crabtech
    Crabtech Junior Member
    Alright cool I'll go check it out. Btw where can I get a copy of the factory service manual for my Prius?
  3. Dan Matthews
    Dan Matthews New Member
    WOW! I just replaced the hybrid battery in my 2004 Prius (110K miles) with a 2009 battery from a junk yard and I was SURE I did everything right and no joy, error lights. After twice tearing down and putting everything back I discovered THIS photo and LoAndBehold that did it. When I removed the plug I couldn't see it yet and didn't notice the slight slide before the flip (and to restore it the slide up after the flip up) All that trouble and that's all it was. I am now on the road again (and about to install an EV conversion kit, yay)
    Chazz8 and PriusCamper like this.
  4. PriusCamper
    PriusCamper Senior Member
    13,460
    5,431
    Pacific Northwest, USA
    What kind of EV kit you putting in?
    And how much did it cost you?
  5. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    Your the first person I have heard of with a bad pack on a Prius and at such low millage? What went wrong?
  6. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Didn't you know? Prii can only go 109k miles. :LOL: Sorry, couldn't help myself. :sick:
  7. Dan Matthews
    To answer the questions on my previous post: I am putting in the Enginer kit, 4KWH version. I figured if I was going to tear down my car I might as well install the conversion. I am almost done so I will let you know how it goes. It is a well built unit but if I weren't previously a mechanic and an electrical engineer I would be more intimidated. In hindsight the hybrid battery change was easy, but it was hard to follow the instructions on-line. I finally used the "Toyota Prius Dismantling Manual" which was very helpful. Even it lacked the instruction that the plug to disable the HV has an extra motion-slide to enable it. I got the tip of using a junkyard battery with guidance to get it as new as possible and ask about the miles (mine has 15K miles from a 2009 for $500 while the old battery had 109K miles). As to WHY it died at such early mileage, I live in AZ and drive the five of us everywhere in serious summer heat, even making monthly cross-desert treks to Mexico which are blazing hot. I have gone through lead acid batteries in every car I own in three year increments.
    minkus likes this.
  8. Dan Matthews
    Enginer kit, 4KWH version, $3500.
  9. Squidgy
    Squidgy New Member
    Exning
    PriusInParadise--thanks so much for this picture/discussion. 1/3 inch of travel on a piece of plastic, and my baby is back, up and running. Sure, I'm the fool for saying to myself "hey, what's this do?" as I pop the fuse off and inspect it...THEN see the label that ominously says "DO NOT EVER TOUCH THIS THING" or something like that.
    In retrospect, I find it a little silly to put the HV interlock under three layers of carpet, panelling, and spare tire kit, when it's purpose is to cut the circuit IN AN EMERGENCY. Sharing with my Prius friends--thanks again.
  10. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    It's not for emergency. It's simply the "service plug" for technicians working on the car. Removing it doesn't kill power to the car, just HV to the engine room.
  11. TurboPriusV
    TurboPriusV New Member
    I need to offer you a HUGE thank you. This big orange switch isn't intuitive, like you guys said.
    It has 3 steps:
    1.Insert
    2. close lever to lock, and
    3. SLIDE IT TO THE RIGHT!
    The picture with the blue lines indicating final position was worth a ton of cash.
    Saved me a frivolous tow job, and a service fee.
    I slid it in place for step three, attempted starting car, got same error. Cycled Power Button Off/On 3 times rapidly to clear error, and car started right up. Thanks! Thanks! Thanks!
    Vit@liy likes this.
  12. Joseph Sis
    Joseph Sis New Member
    Medford, Oregon
    OMG! This thread, and those photos if the disconnect, saved me hundreds of dollars, days without my car, and utter embarrassment!
    That 3/8" slide - who knew!?
    Also the steps to reset the error!
    Thank you so much!
  13. Motov8r
    Motov8r Member
    102
    x3
    This thread helped me make it to work today. Installing an amp and speakers over the weekend, jumped in this morning and prius no workie. A quick search and slid the lever up, on the road again.
  14. Felice
    Felice New Member
    Belgium
    Hello everybody (and yeah, this is my very first post on this fantastic forum I've already consulted millions of times, what a gold mine of precious information!)
    So, I'm posting here because I have just installed an aftermarket stereo/gps android-based system to replace the original one, almost eveything works fine except the fact that I get a "Check hybrid system" message (though the car switches on normally and drives correctly).
    Any hint ?
    Thanks!
    Felice
  15. bisco
    52,849
    12 volt battery okay?
  16. Felice
    Felice New Member
    Belgium
    Hi Bisco thank you for your reply. Actually, after I restarted the car today, the "check hybrid system" message disappeared. I've seen on other posts that when you disconnect and reconnect some wire (especially when removing the plastic parts of the dashboard to remove the original stereo) you just need to start the car 3-4 times for the message to disappear...
  17. bisco
    52,849
    congrats!(y)
    Felice likes this.
  18. jqsmooth
    jqsmooth Junior Member
    Where is this lever on Prius C? I can't find it.
    NVM, I found it. It is in correct position but I'm still getting error message.
    #38 jqsmooth, Feb 18, 2016
  19. InPriusLove
    InPriusLove Member
    167
    42
    California, US
    2015 Prius c
    Nevermind. Not a time traveler.
    #39 InPriusLove, Feb 25, 2016
  20. Olekbyc
    Olekbyc Junior Member
    Was installing a hitch for my 2011 Prius and out of curiosity pulled that big orange fuse :oops: good thing I found this thread, cleared my "check hybrid system"
