Check Hybrid System, Won't start, and No codes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Domingo, Aug 28, 2017.
  1. Domingo
    Domingo New Member
    Seattle Wa
    OK I checked the AM2 fuse and it's fine. NO evidence of rats either. If you have another idea, I am all ears, otherwise to the dealer it goes...along with my rectum.
  2. JC91006
    16,930
    8,639
    Others that are more familiar with this generation will tell you. This could end up being an inverter problem, and it'll be free to fix
    #22 JC91006, Aug 28, 2017
  3. Domingo
    Domingo New Member
    Seattle Wa
    Free to fix would make me happy as hell. Thanks for the help.
  4. JC91006
    16,930
    8,639
    But right now I'm suspecting a fuel delivery problem. But we'll see. Reading codes will give a better idea
    m.wynn likes this.
  5. Mbarton557
    Mbarton557 Junior Member
    Mississippi
    The hybrid battery is in the trunk area. Warranty 100000 miles 96 mos I think
    iPhone ?
  6. Mbarton557
    Mississippi
  7. Domingo
    Domingo New Member
    Seattle Wa
    Well, I took it to the dealership and they are looking at it right now. I will post a response with the cause and solution when I know it.
    bisco, Raytheeagle and JC91006 like this.
  8. Domingo
    Domingo New Member
    Seattle Wa
    Alright! It looks like the power inverter box (The big silver box under the hood). The repair guy said it was totally shot and needed to be replaced. Thankfully, it was covered under the warrantee so the $5000 bill is now $0. Thank God!
    Rebound, Grit, esam1975 and 2 others like this.
  9. JC91006
    16,930
    8,639
    Interesting how you drove home without issues. Anyways, great outcome
    m.wynn likes this.
  10. ArleneG
    ArleneG New Member
    Vermont
    I am having the same issue, it was saying "Check Hybrid System" for about a week and we made an appointment at the dealer, but it wouldn't start yesterday so I had it towed to the dealer for its appointment.
    They worked on it all day but they said it wasn't giving any diagnostic codes, and they can't find the problem. But it drives for them. What to do? Just take it back and see if it does it again?
  11. bisco
    52,754
    i would start with the 12v battery. is it original?
  12. Mrs.Diamond
    Mrs.Diamond Junior Member
    66
    Minneapolis, MN
    Did you get your issue resolved? Sometimes a failed power inverter pump causes these issues. Also check Am2 fuse
  13. Kari Armstrong
    Kari Armstrong New Member
    Kentucky
    I have been reading, and I had the problem as his, and when resetting by the negative cable it will start again, then comes back on, til I turn the vehicle off. Repeats the process. Most morning after sitting, it will start fine, but has the triangle, VSC, and break system light after a few miles. Have to reset to start it back. I had HV and 12v battery replaced? Any suggestions! It’s my only vehicle so have been doing the reset for about a week, works each time to start the vehicle, I know not a good idea. Only option at this time. I have been to different shops, clearly they don’t know much about Prius, I was told HV battery, then transmission, then 12v battery? I’ll take any suggestions or tips on what to check?
  14. JC91006
    16,930
    8,639
    The problem your car has lies in many possible places.
    1. HV battery
    2. Transaxle
    3. Inverter
    4. AC compressor
    Maybe the HV battery has a leaking module that can be changed out, or maybe the inverter is bad and that can be changed out. These 2 are the easier of the problems to have. But you really have to go through a diagnostic tree of symptoms and figure out the origin of the issue.
    The more common of the 4 causes listed, is the HV battery having a leaking module.
  15. Lino
    Lino Member
    61
    38
    I blew the engine on my Prius, rod put 4 holes in the block including going into the AC compressor, I just finished installing another engine, and it starts then shuts off, giving me a fault that says check hybrid system, engine not starting, but it does start for a few seconds, 10-20 then shuts off.
    I do have the AC compressor disconnected because it is damaged on top cover and electronics board, possibility that it shorted something out when the rod went into to it.
    My question is do I need the AC compressor plugged in to not have this issue.
  16. ilya1
    ilya1 New Member
    oregon
    how do i reset the tpms if touching the little connectring thingy under the control panel on the left of the driver seat and i touched the white wire thingy and touched it to ground to put the tpms to learning mode and it doesnt work its still on any way to fix this? its a nissan 2010 nissan altima
