Check hybrid system
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Manhal K Alrashdan, Dec 2, 2015.
  1. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    16
    jordan
    What does this message mean when appears on the display. The car has 162000 miles.
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    It could mean almost anything, it's a very generic and not uncommon error.
    You have to give us more information on any other warning/error lights, battery age/status, other specific driving conditions, error codes (DTCs), etc.
  3. Mendel Leisk
    42,369
    I've got "check hybrid system" close to half dozen times now, and yeah, it seems to be a catch-all alert, could be for anything.
    One of the first times was after I got the recall for inverter software update: they told me the car was ready, and when I started it up got the message. They took it back for a few moments, and next time the message was gone.
    All the other times, it was braking system related, accompanied by various traction control and brake warning lights, and brakes going into a sort of failsafe mode. The service manager now "thinks" there may be nothing mechanically wrong, that the issue is mess-up in the communication protocol.
    Manhal K Alrashdan likes this.
  4. Fizfaz
    Fizfaz New Member
    Birmingham
    Active
    Hi I drive a 2010 hybrid prius active and last two times my car says check hybrid system went to the dealer when it first appeared and the dealer cleaned the vents the air ducts and then there was fine. and then another 2 weeks later the dealer change my auxiliary battery and then I had the car back 2 Days Later it said again check hybrid system please help if anyone has any resolutions
    185000 miles.
    59 plate vehicle
    2010 model
  5. bisco
    52,891
    welcome!
    did the dealer read any trouble codes?
    where are you located?
    what is a 'hybrid prius active'?
    what is a 59 plate vehicle?
    is the battery intake grille clear?
  6. Mendel Leisk
    42,369
    Yeah second the trouble codes. If the system said "check hybrid system", there will be codes.
    @Fizfaz is (now?) giving location as Birmingham, and "59 plate" vaguely rings a bell, some level or option package in Britain?
  7. bisco
    52,891
    right, couldn't get alabama out of my head, thanks.
  8. Fizfaz
    Fizfaz New Member
    Birmingham
    Active
    I'm in UK
  9. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I think your dealer is just using you as an ATM.
    The dealer should have scanned the car first, before just replacing parts.
  10. Fizfaz
    Fizfaz New Member
    Birmingham
    Active
    Have fixed the car before Xmas eve. Got a new battery. For a £1000.00 guy in Coventry
    specialises in hybrid cars
    Dealer quoted a £1400.00 supply n fit
    Driving for 2 weeks now. So far so good
    Anyone need contact no. Let me know
  11. Sleepy Brown
    Sleepy Brown New Member
    Los Angeles
    When the Prius runs out of gas it switches to the battery mode, which without gasoline almost immediately runs out causing the Check Hybrid System light to go on. Fill up the tank to recalibrate the gas gauge and it should be good to go.
  12. anand_j
    anand_j New Member
    Jacksonville
    please dont buy prius.. repair costs 5000 dollars
  13. anand_j
    anand_j New Member
    Jacksonville
    I just got Check Hybrid system light and i am driving fine with it and the next day I took it the dealership to see why the message is coming .. they are charging about $5000 repairs. please help me advice what is the point of going with hybrid.
    Is the dealer cheating,
    Mileage is just 105K and for just saving Gas money I went to Prius hybrid. Now it is costing me 5000$ for repairs. I recommend there is no point of going with hybrid cars if the repairs of the AC Inverter so expensive.
    Anand
    904 599 9763 cell
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    To save the world, and bring back global cooling.
  15. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
    Grit likes this.
  16. Mendel Leisk
    42,369
    I wonder if the ECU actually needed replacement?
    A 2015 with 105K miles, it was determined to be out-of-warranty? What was the cut-off date/miles, did they say?
    There's tires (2 sets of 4??), wheel alignment, brakes, coolant change (both), light bulbs, in that invoice, btw.
    davecook89t likes this.
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Anand
    904 599 9763 cell
    Calling all robocallers.
  18. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    If the inverter truly needs to be replaced, you can save about $3k by going with a used one from a wrecker for a few hundred dollars. You would also have to find an independent mechanic capable of replacing it, if you cannot DIY. In fact, all of the other items listed on the work order, except the tires, alignment and brake pads (which may not even necessarily need to be done at this point) are easy to do yourself. Regarding the inverter, if you could find alternate transportation in case of failure, I believe you cannot lose by continuing to drive the car until it actually fails and then decide what to do. It sounds like you have not had much experience with dealer pricing. Generally, with an older car, you should really only take your car there as a last resort.
