Check Hybrid System
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GerryC11Pr, Dec 24, 2017.
  1. GerryC11Pr
    GerryC11Pr Junior Member
    22
    Southern California and sometimes Mexico
    Well here we are on a trip to Vegas from Phoenix and half way in Nothing AZ, the check Hybrid System lights up. How long until it completely dies?
    Still have 2 hours to go... Thinking about stopping in Kingman AZ and see about renting a truck n trailer to finish the trip and check it out in Henderson. It as 153k miles. 2011
    Gerry
  2. Mendel Leisk
    38,738
    Oil level ok? Coolant levels?
    Anything and everything can trigger CHS warning and engine symbol. A momentary signal loss, hopefully.
    #2 Mendel Leisk, Dec 24, 2017
  3. GerryC11Pr
    22
    Coolant is at the low mark
    Oil is 1/2 qt low
    Everything else is full.
    I'm at autozone going to check codes
  4. GerryC11Pr
    22
    Codes read...
    P0A80 - replace Hybrid Battery Pack
    Well my options are:
    1. Tow it to Henderson find shop
    2. Tow it to LA (where I live) DIY
    I can do the work myself with help from friend. But in LA. Since I am on way to Vegas now will have to tow it with u haul truck and trailer. Then to LA
    Gerry
  5. Mendel Leisk
    38,738
  6. jerrymildred
    jerrymildred Senior Member
    11,515
    14,118
    Tampa, FL
    Yikes. Not that there's ever a good time for that, but this is worse. Glad you're the kind of guy who can take care of himself. I think, if it was me and I already had it on a trailer, I'd rather work on it myself at home.
  7. MelonPrius
    MelonPrius Senior Member
    823
    509
    Las Vegas
    Wow, Gerry, so to hear this- especially when you're so far from home.
    This seems a bit premature as it's only a '11. You're barely past the CARB warranty of 150 miles. I'd contact Toyota's customer service and inquire about a good will credit for a new battery. Good luck.
  8. bisco
    49,510
    check it with tech stream before proceeding. if it does turn out to be the battery, call toyota, they may help defray the cost.
