Check Hybrid System
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kyleallenftw, Oct 10, 2020.
  1. Kyleallenftw
    Kyleallenftw New Member
    Topeka, KS
    I've got a 2010 Prius III with just under 160K miles on it. The other day, I turned my car on and got a message saying "Check Hybrid System." I can't put the car into gear- only neutral. The gas engine won't start up.
    I've been troubleshooting as best I can; starting with pulling the orange hybrid battery plug. I put a brand new 12V in it, topped up the gas, and cleaned out some residual oil from the air intake.
    Still no luck. Any ideas of what might be happening?
  2. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Grab the cel codes otherwise you’ll be blind troubleshooting.
    pjksr02 likes this.
    52,391
    check the battery cooling fan
  4. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    If you don't have a good code reader, now is the time to get one.
    Have you had all your warranty repairs completed?
    It could be the Intelligent Power Module ("inverter"), if yours is original. Not sure if the enhanced warranty is still covering these. But when mine went out, I couldn't start the system at all, or shift. So, maybe the hybrid battery is more likely.
  5. Kyleallenftw
    Topeka, KS
    Got a code P0A0D - High Voltage System Interlock Circuit High.
    Bought a salvaged inverter off eBay and swapped it out. Car started right up.
    Problem solved.
    pjksr02 and bisco like this.
  6. bisco
    52,391
    congrats!(y)
  7. Joe Chanes
    Joe Chanes New Member
    16
    Ellensburg
    I had a PA093 Code for the inverter cooling process. swapped out the inverter pump, and now i cant get any response. I am wondering if the inverter itself just crapped out like yours and needs replacing. was yours off ebay "refurbished"?
  8. bisco
    52,391
    try looking for a lowish mile salvage
  9. ASRDogman
    ASRDogman Senior Member
    7,822
    3,984
    Was it hard to relace the inverter pump?
  10. Joe Chanes
    16
    Ellensburg
    Yeah, I think I may try an inverter swap before that not sure
  11. Joe Chanes
    16
    Ellensburg
    No not really, there are some good YouTube vids on it
  12. ASRDogman
    7,822
    3,984
    I haven't found any "good" video's for the inverter pump replacement.
    About 2 years ago I saw one where he didn't remove the fuze box or inverter, but I can't locate it.
