Check light
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Vanne, Oct 17, 2012.
  1. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    I just add buffer speaker to my Prius 2004 and after a few hour it have check light appear what is problem ? It relate to electrict system or not ? Thanks for your share
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I'm sorry......are u saying that u added a sub woofer & after a few hours the CEL (Check Engine Light) came on?
    If this is the case, did u unplug ANY electrical connectors? Sometime if u unplug certain connectors, it will cause the CEL to come on because the data link between the cars computers was lost. This can be cleared by using a OBDII scanner.
  3. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    Yes it is sub woffer I didn't unplug any connector Im not do it my self I get it to dealer and they connect for me but after a few hour CEL light come on so I worry about it going to destroy computer system or something wrong
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    If u have a OBDII scanner, use it to scan for the error codes. Then u can search for the code definition & it will tell u what can be the cause or u take it to the dealer & have then run a check. A CEL could be a 100 different causes & only the code will point u in the right direction. It could have nothing to do with the woofer install.
  5. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
  6. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    i'd take it back to the shop that put in the sub and tell them what happened. they should at least scan it to determine if it is related to the work they did.
