Check List
Discussion in 'Prime Main Forum (2017-2022)' started by huskers, Nov 13, 2016.
  1. huskers
    huskers Senior Member
    2,550
    2,489
    Nebraska
    When you take delivery (for those of us who have not physically seen the car until then) what should you look for/ask/make sure you do before leaving the dealership with your new shinny Prime?
  2. kenji4861
    kenji4861 Member
    137
    62
    Other than the usual checking around for dents, scratches, scuffs...
    take it out for a drive. Does it drive straight? Any strange noise? Covered by warranty and it's a toyota afterall =P
  3. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    Two key fobs.
    A full tank of gas.
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Portable Charger
  5. Pizza Driver
    Pizza Driver Active Member
    158
    156
    United States
    Get them to turn off the backup beeper.
    Robin Mitchell and Prius Maximus like this.
  6. MikailSJ
    MikailSJ Member
    35
    27
    Bump. Any other suggestions? I am picking up my new Prius soon!
  7. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    Make sure you get two key fobs $$$$
  8. Mendel Leisk
    42,349
    Ask to see the Pre-Delivery Inspection, that should be pretty good hit-list. Verify a few of the items on it, whatever catches your eye. Tire pressures, two fobs, the Owner's Manual and Warranty/Maintenance Booklet, Tonneau Cover, floor mats. You could also pop the hood, eyeball the anti-freeze levels, check the washer fluid dipstick, engine oil dipstick, if your really want to go nuts, lol.
  9. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Turn off backup beeper, change "times of flashing of the lane change signal flashers " from 3 flashes to 5, check for any accessories you ordered (floor mats, whatever). I also had them turn off vehicle speed linked seat belt reminder buzzer (I always wear my seat belt and don't need a reminder).
    I think a full charge is the least they can do.
    Make sure it has a jack (under left rear seat), and a tool kit (not sure where it will be but it's a triangular pouch that includes the lug wrench/jack bar). Make sure the charge door opens and the cap is on the left side (if its on the right side it can jam the door closed).
  10. fneil
    fneil Member
    71
    52
    Carrboro, NC
    Make sure the A/C and heat work, in EV mode. My wife's new car had a refrigerant leak, but as we bought it the winter, we didn't notice we had no A/C until spring...
    In the Prime, you would have no heat as well (heat pump...), so you'd be less likely to miss such a problem.
  11. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    i have them remove any and all window stickers ...
  12. huskers
    2,550
    2,489
    Nebraska
    I had my whole list ready to go when I got my car. Once there I was so excited to get the car I forgot most of it. Went over it all once home.
  13. I quizzed them to see if they knew more than I did from reading PriusChat :D
    (turns out the one guy and I were nearly dead even)
    pilotgrrl and Mendel Leisk like this.
  14. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
  15. Mendel Leisk
    42,349
    The managed to get one discreet dealership decal on our hatch. Not too flashy, I let them live... :cautious:
    pilotgrrl likes this.
  16. pilotgrrl
    891
    1,797
    Chicagoan in TX
  17. Mendel Leisk
    42,349
    Me too, since tasteful license plate frames don't stand a chance with me, heehee.
  18. Lee Jay
    5,850
    4,036
    Me too, that's why I threw away the one the dealer provided and replaced it with one that says, "Plug in POWER!".
    And I peeled off the dealer's name stickers too.
  19. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    bump. if they wan't me to advertise for them, they can pay me.
    I can live with a license plate frame (at least it holds the temporary plate on until the real one comes in), but I won't take a car that has a dealer logo stuck on the paint.
  20. DavidA
    2,349
    1,825
    Chicago western burbs
    Did they reduce the tire pressures on all 4 tires to usable pressures? All 4 of mine were 45psi. Did they charge the car up, and is there even a L2 charger at the dealership? If so, can customers use that L2 charger for free? What type of dealership labeling do they place on your car? Un-removable sticker, riveted badge, or user removable license plate frame? Did they make you pay for some hocus bogus vin etch or fabric treatment?
    +1 on the annoying backup beeper. If you can, make that a n/c condition of the sale.
    Did they set up the Safety Connect for you? Does the 3 mos. free SiriusXM radio work? If you have a smartphone, can they show you how to DL the software and connect it with your car?
