check oil level with engine warm or cold?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mike_10, Jan 15, 2011.
  1. Mike_10
    Mike_10 Member
    73
    Boston MA
    I've read the pages on engine oil level and changes in the awesome 2004-2009 manual by John's Stuff - Toyota Prius and more.
    Great information on overfilling of engine oil. Among others I read:
    "The ideal level is 1/4” (one-quarter inch or 6 millimeters) below the "full" mark, which is between the D and the E on the photo above." (p.27)
    Now I wonder whether to check this when the engine:
    a) is cold
    b) ran for two minutes (to whip the oil around)
    c) ran for two minutes (to whip the oil around) - and wait 5 minutes
    d) is warm (oil is whipped around the engine and the oil is much "thinner" than when the engine is cold)
    e) is warm (oil is whipped around the engine and the oil is much "thinner" than when the engine is cold) - and wait 5 minutes.
    f) other:......................
    Thanks!
  2. Mendel Leisk
    38,253
    Never found it to be much of a factor. I agree with 1/4" below high mark as being a good sweet-spot for intital level after an oil change. That ensures you aren't overfilled, and gives lots of elbow room on the down side.
    Transmission fluid levels are often spec'd to be checked hot. I've always found that to be difficult and contradictory, and settle on cold check for them as well.
    Most consistant measures are likely when taken after an overnight sit.
  3. Mike_10
    Mike_10 Member
    73
    Boston MA
    In my case it looks like it does matter a lot: my oil is about 1/4 inch overfilled if the engine is cold, and I see no oil on the dipstick when the engine is hot. That's why I'm asking...
  4. Mendel Leisk
    38,253
    Is your hot check while the engine is actually running? That's the only reason I could see for such a disparity.
    Regarding being 1/4" over top mark when cold, I'd put that down to a service department who's first priority is giving "full measure", and of course charging you for it. While that's not gross overfill, it's an irritant. Better to fill it a bit under top mark and give you the remainder of the bottle.
    Overfill is detrimental to mileage, and if overfilled enough can do damage to seals.
    That's assuming your getting the oil changed by pro's.
  5. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I've found the 0w20 oil to be very clear and almost impossible to see on the dip stick sometimes.
  6. Mike_10
    Mike_10 Member
    73
    Boston MA
    it's 5W-30 and I see it clearly when the engine is cold, but I see nothing when it's warm.
  7. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    ooops sorry. I mixed your join date of 2010 with the model year. :eek:
  8. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    You can check it hot or cold. But it must be off and you need to wait at least 10 minutes after you shut it off for all the oil to drian own into the oil pan. If you check it right after you shut it off it will read lower than it really is.
  9. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I only check when cold. When traveling and filling with gas when checking of course the engine will be warm. I use 0-20 in my G2, so it is even harder to see. You must get the angle and light perfect to see it. I don't check until after the fill up in order to let the oil drain into the pan. I would not use 5-30. I believe Toyota even specifies 5-20. 0-20 or 5-20 will give you better FE and help lub. the engine on cold starts.For what its worth, H
  10. Patrick Wong
    18,199
    6,464
    I assume that you are checking the engine oil when the engine is hot, and you have waited at least 5 minutes after making the car IG-OFF. Remove the dipstick and wipe it off, then reinsert it and remove it again. Hold the dipstick so that its flat surface is reflecting the available light into your eyes. Then you should be able to see what portion of the dipstick is wet with oil.
    In any event, if you see that the oil dipstick level is 1/4" above full when the engine is cold and the car is IG-OFF, then you need to drain ~1/4 quart, to bring the oil level near the full mark.
  11. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    +1. Works every time for me - hot or cold. Good luck! :)
  12. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    I haven't done it yet on my Prius, but on other cars I have noticed no obvious difference in oil level between hot after sitting 10 minutes and cold after sitting overnight in the same place. Since the laws of physics also apply to a Prius, I dont expect anything different on my Prius.
  13. Shorsh
    Shorsh New Member
    Årby, Södermanlands Län, Sweden
    Hi everyone !!
    I have a toyota prius 2008-2009 and i bought it before 1 week and i wanted to cheek motor-oil level but i have problem with dipstick that i cannt pulled up its so hard id ont know why ?!! Can some one here tell me why ?!? Thanks alot
  14. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    Hej
    The dipstick is somewhat tighter on the Prius, not loose like on many cars. Just pull a bit harder, it should come as there is nothing unusual about it otherwise.
  15. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    I have never heard of checking oil when engine is cold. ever. I learned to always check oil with a warm engine.
  16. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    I have always checked levels when cold.
