Check out Hybrid Assistant on Google Play Store!
Discussion in 'OBDII Android App' started by Kelvin660, Dec 17, 2016.
  1. Kelvin660
    Kelvin660 Junior Member
    Stonehouse, UK
    The best app I've found (better than Tourqe) for Toyota Hybrids. Gives real time info of all important parameters.
    Also has a report writer to analysis trip information...
    Check it out, you won't be disappointed!
  2. garglo
    garglo Member
    99
    45
    Port St Lucie, FL
    2020 Prius Prime
    Couldn't get it to work. Connected to OBDII, app runs but does't show any data.
  3. RCO
    RCO Senior Member
    3,709
    5,183
    Cornwall
    Haven't tried it myself yet, but noticed in the blurb that you have to disconnect all other Bluetooth connections from your phone/pad before connecting the odb2 sensor to it. Worth a try or not, I don't know!
  4. leokowalski
    leokowalski Junior Member
    Germany
    Hello, this Program ist absolutely awesome!
    And it is absolutely free!
    After you (automatically) recorded a ride with "Hybrid Assistant", you can use "Hybrid Reporter" to plot and analyze.
    ALL the data and efficiency of this ride.
    I am so much impressed of this software! You can switch to MPG.
    Here is a small piece of this report, where you can see Winstons (ccdisce) ECT-Spoofer in action. :
    The Bluetooth-Adapter was a cheap china Clone of the ELM 327.
    I also added a full report of this journey, done in a 2016 Toyota Auris (like 2015 Prius).
    Regards
    Leo Kowalski
    Edit: In the report you can see, it is wintertime in Germany!
    P.S. Search for "hybrid assistant" in youtube! ;)
    #4 leokowalski, Jan 7, 2017
  5. Kelvin660
    Stonehouse, UK
    It's also good for checking the LV and HV battery condition... 1483785878039.png
    leokowalski likes this.
  6. kadeR
    kadeR Junior Member
    Portugal
    Couldnt put it to work with an yaris hsd. With torque pro its working ok.
  7. Kelvin660
    Stonehouse, UK
    I had the same problem. Using a small cheap ELM327 it didn't work but it does work with a bigger (longer) cheap older ELM327 that I have. Both work with Torque Pro! Try borrow another OBDII. I'm thinking of buying the recommended device when I can find a reasonable priced one due to its faster speed...
  8. amjohnson
    amjohnson Junior Member
    77
    US
  9. bisco
    49,371
    seems a few above have.
  10. glutaman
    glutaman Member
    73
    26
    Dublin, Ireland
    Choose your OBDII adapter and good to go, sooooo easy to use! Some reading to understand all the elements was mandatory for me, but it's totally worth it :)
    I have a small issue with the Hybrid Reporter though - Google map overlays show only the map without data.
    Edit: I'm using it with the Carista adapter, and it stays above 100 PIDs/sec (for 90% of the time) while playing music over BT.
    #10 glutaman, Apr 3, 2017
    RCO likes this.
  11. ♡myPeeus
    ♡myPeeus Junior Member
    61
    57
    US
    Does it require bluetooth on your screen? That is one option I dont have. But I purchased a OBDII reader and I have had one chance using it and because the problem was battery related and the reader needs a power supply, curious how this app actually works if not by Bluetooth.?
  12. glutaman
    glutaman Member
    73
    26
    Dublin, Ireland
    Can't believe I finished the first tank using the app with +2 MPG (UK). Second talk half way and it's currently at a further +3!
  13. swapper
    swapper Junior Member
    Spain
    The recommended OBDII adapter for this program is OBDlink LX
  14. glutaman
    glutaman Member
    73
    26
    Dublin, Ireland
    This is so expensive. How many PIDs/sec do you get with it? Does it have any functions that would justify the price being 4-5 times of some other adaptors?
  15. swapper
    Spain
    Over 100 PID/second
    With this adapter you will be sure the Hybrid Assitant program will run ok, so:
    Without a fast OBD2 adapter you could not make these actions and obtain usefull reports.
    #15 swapper, Jun 18, 2017
  16. glutaman
    glutaman Member
    73
    26
    Dublin, Ireland
    Thank you, I can clearly see a difference in "refresh rate" in your video!
  17. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,889
    Columbia, SC
    OK, so I downloaded the hybrid Assistant and Reporter Apps the evening of 8/1/17. I purchased the recommended OBD Link LX Bluetooth adapter a few days earlier. I open the app and go into the tool section, touch the "About" button and it's showing the most recent release is 1.91.2. I adjusted the settings to have everything in Fahrenheit/Miles/Gallons.
    Everything links up and it monitors the car and it provides the report. My question is the accuracy. Keep in mind, I'm not even close to being an expert on apps, especially stuff on a phone, but there's some things that give a first impression of a real amateur feel. I have to admit they definitely jam a lot of info onto a screen. Some things still do not display in F/M/G
    I used it on my drive to work this morning and then generated the report. Trip summary shows 22.16 miles (accurate) and breaks it down into some details. Seems fine. Does a speed evaluation/breakdown. Seems fine. Does a HV battery state of charge and altitude change breakdown. Seems fine. BUT....and here's an important one...the fuel evaluation. It states: Consumption 6.844 mpg, Usage 3.238 gallons, Cost $6.476 (I had programed in a cost of $2/gal). Seems off a little bit, considering my current MFD is showing 49.2 mpg with about 300 miles so far on this tank of gas. I thought maybe it's off by a decimal place, but no that would put me at 68.44 mpg and 0.3238 gal. No matter how much I would love to see those numbers, let's be real. That would be about >30% better than the best tank I've ever had (52 mpg and about 430 miles on MFD)
    I tried "The Google Monster" but didn't come up with anything regarding the app or how to correct it. Any ideas?
    Maybe I'll put it back to metric mode for the drive home to see how it does.
  18. Radu Stauceanu
    Radu Stauceanu Junior Member
    Romania
    search for Hybrid Assistant on Facebook. The devs are active there.
    Tell them.
    RCO likes this.
  19. TMR-JWAP
    6,193
    5,889
    Columbia, SC
    I have managed to keep Facebook out of my life. I was hoping to keep it that way, as I'm not a 'social media' type person. Unfortunately, every day, something comes up that keeps pointing toward going that direction.
  20. RCO
    RCO Senior Member
    3,709
    5,183
    Cornwall
    Unfortunately, for the like of you and me social media is the cheapest form of advertising to a super-wide potential client base because of the way it works. For every couple of folks they lose through that specific medium, there are another couple of thousand they gain. I'd like to believe the smarter ones keep other lines of contact open, but.....
