Check PCS system issue and solution
Discussion in 'Gen 3 Prius Main Forum' started by -JnC-, Dec 26, 2022.
  1. Leadfoot J. McCoalroller
    8,283
    7,794
    Pennsylvania
    2018 Prius c
    A reply to this specific point: in my case, I jacked up the car, removed the wheel, and was undoing the wiring for the speed sensor when I first saw the flood of new blue grease in places it shouldn't have been.
    ^ All of that ^ took less than 10 minutes.
    Maybe just take it back to the place that did the bearing and ask them to spend 10 minutes looking?
  2. Rocky Mountain Priusman
    Rocky Mountain Priusman Active Member
    224
    112
    Canmore, Alberta, Canada
    I have an update and the problem has been solved.
    Got the car back to the mechanic that installed the SKF wheel bearing and hub assembly in January.
    They had a look and this new SKF brand wheel bearing and hub assembly (which includes the sensor) had already failed. The sensor was toast, AND the bearing was already starting to fail. This is after 4 months and maybe 3000 kms of driving.
    So the entire bearing hub assembly was replaced under warranty. They did not charge me extra labour. All of the lights/warnings are now gone and all systems work as normal - the car is out of Limp Mode.
    Lets hope that was just a one off and very defective part. But I do regret not going with OEM now. I am going to keep a close eye on this new part and if I hear any noise coming from it within a few months I will ask for my money back and replace it with a Toyota part.
    The main reason I went with SKF was simply that it was going to take a few extra days to get the Toyota part shipped in. It was also slightly more expensive for the Toyota part. Lesson learned!
  3. Rocky Mountain Priusman
    224
    112
    Yes this is the lesson I learned. I should have learned it a few years back when I went with an aftermarket 12v battery and that failed pre-maturely.
    From now on for most applications I will only buy OEM Toyota parts.
  4. ASRDogman
    ASRDogman Senior Member
    8,056
    4,084
    You just can't with cheap parts anymore. I went through that will TRQ.
    They are no longer of any quality. Mine lasted less than 3000 miles.
    As did the 2 replacements.
    I went with Timken for the rears, and Moog for the front. They've lasted over 100,000 miles...
  5. Najeeb
    Najeeb Junior Member
    Ontario, Canada
    Technology
    TL;DR: Had a similar PCS issue, resolved by having the leaking brake lines replaced.
    I drive a 2010 Prius with 320k km (200k mi). I noticed an intermittent PCS error appear for about a week before staying on perpetually, which was coupled with the loss of brake booster power. After a few days of constant PCS error, the car began beeping constantly (louder than the beeping when you shift into reverse) and it was clear that the issue was brake related. After taking it to a mechanic, they found that the brake lines were leaking. This was fixed for about CAD$300. It's been working great without issues after that. So that's another possible cause of the PCS error.
