Check Prius Battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Naushi Hussain, May 13, 2015.
  1. Naushi Hussain
    Naushi Hussain Junior Member
    16
    Fountain HIlls AZ
    I have a 2010 Prius - Is there a way I could check the health of the battery without having to lift a dozen other parts. If I go to a dealer they will find 30 different problems with the car. Any help will be appreciated. I just don't want the battery to die on me one day.
  2. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    Which battery - 12V or traction?
    If 12V, you can check the voltage using the jump point under the hood. It's in the manual.
  3. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    If you have random fault codes 12V battery is likely suspect. Best to measure the voltage after it has sat for long time (like overnight). You can check the voltage from the jump start terminal under the hood.
    HaroldW likes this.
  4. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
  5. qdllc
    qdllc Senior Member
    1,377
    400
    Does that monitor just voltage or amperage as well? Many batteries have healthy voltage but no CCAs compared to where they should be. That's why battery testing has to test to load to see if the battery fails when taxed.
  6. bisco
    52,862
    for the hybrid battery, i think a scan gauge will monitor your voltages, temperature and etc.
    even better, a laptop and mini vci with tech stream software.
    for the 12 volt battery, see rrxing's post #2.
    #6 bisco, May 14, 2015
  7. Naushi Hussain
    16
    Fountain HIlls AZ
    Thank you every one for their suggestions. Does any one know what is the average life of 12V and Traction batteries. How much does each cost. I am always nervous about it.
  8. valde3
    2,002
    750
    Finland
    Prius doesn’t really require CCA from 12V battery for anything. So just checking the voltage after it has sat is (almost always) enough for Prius.
  9. Air_Boss
    4,259
    1,197
    New Yawk
    Voltage and predicted decay.
  10. bisco
    52,862
    the average life of the 12 volt is 4-5 years and costs $2-300. to replace.
    the hybrid battery is probably 10-15 years and $2-3000. for a new replacement. less for salvage or rebuilt.
    i think in arizona, your hybrid battery warranty is 8/100.
  11. Naushi Hussain
    16
    Fountain HIlls AZ
    Thank much everyone for the suggestions
  12. Mendel Leisk
    42,352
    Get a digital voltmeter (cheap ones are $20~30, invaluable for many applications), check voltage, by connecting the positive (red) lead at the jump point under-hood:
    (Page 543 of Owner's Manual)
    And the negative (black) lead to bare metal of the car body.
    If you're getting a reading 12.6 volt or higher, the battery is totally fine. If you're reading 12.4~12.5, you've got an older battery, still some life in it, but worth researching replacement battery. If it's reading 12.2~12.3 volts, there's significant deterioration, consider replacing soon.
    If you want to be proactive: research smart chargers. Used periodically, and coupled with voltmeter monitoring, you'll stay on top of battery status.
    Here's some info on charging. Note the max charge rate of 4.2 amperes. I use a charger around 3 amperes, works fine:
    (Page 563 of Owner's Manual)
    #12 Mendel Leisk, May 17, 2015
