Check your Cabin Air Filter Today!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, May 5, 2006.
  1. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    In a damp climate, the growth of mould would be a greater concern than decreased air flow.
  2. Usman Farooq
    Usman Farooq New Member
    Lahore,Pakistan
    Just got my Prius 2007 Air Filter repalced for $3.5 including Free Installation here in Pakistan.
  3. Cadenza
    Cadenza Member
    125
    43
    LALA Land
    Wow... Can't beat that!!!
  4. theforceprius
    theforceprius Junior Member
    25
    Woodward, OK
    Changed mine last weekend. Found out the glove box piston thing was broken off. Any suggestions on how to fix that?
  5. Yakoma
    Yakoma Active Member
    470
    125
    sss
    I don't know the condition it's in now (broken or completely missing), but it sounds likely you'll have to replace the piston. They're not that expensive and very easy to install. I bet there's a how-to if you search this forum. If you can't locate one, post again. Or, if you have the pieces, you could try gluing it back together using some strong glue like Gorilla Glue. But I wouldn't recommend that. Then again, if you're saying the post where the piston attaches to the glove box is broken off, that will require some more fancy engineering - or a new glove box which ain't cheap.
  6. theforceprius
    25
    Woodward, OK
    Yep the pin that holds the piston is broken off. I think the previous owner might have not know about it and brute forced it open.
  7. Yakoma
    470
    125
    sss
    In that case, I'd take the glove box out and try to find a screw or nut/bolt combination that you could drill into the box to act as the piston pin. Seems doable.
    cyberpriusII likes this.
  8. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,850
    Hyampom
    Maybe a little late to this, but I think it would be quite easy to put some sort of "stud" (HMMM), through that spot and "fix it" it that way. The whole box thing comes out quite easily (this coming from a woman who six years ago could not figure out how to GET to the Cabin filter.
  9. Greg0764
    Greg0764 New Member
    st. paul, mn
    I removed mine.
  10. cyberpriusII
    1,157
    1,850
    Hyampom
    I have run the car without the cabin filter now and again -- when the mice have totally peed all over it and shredded it and the parts store could not get another $4 filter for several days.
    I like to keep it in there, not because I believe it does much in terms of air quality, but it keeps the mice out of the fan, so I don't have mouse parts flying about the car.
    CanuckPT likes this.
  11. Okinawa
    Okinawa Senior Member
    1,333
    320
    With your allergies you may want to consider upgrading to a Toyota charcoal filter.
  12. bisco
    52,863
    the problem with removing it is that a lot large debris collects in there. you will wind up with leaves, pine needles and etc. in the fan and vents.
  13. cyberpriusII
    1,157
    1,850
    Hyampom
    And "meeces" pieces.....:ROFLMAO:
    #233 cyberpriusII, Apr 11, 2015
    Data Daedalus and bisco like this.
  14. bisco
    52,863
    oh well, you can just point the vent at your face and catch those in your moth while driving. tasty morsels.:p
    #234 bisco, Apr 11, 2015
  15. Yakoma
    470
    125
    sss
    I just threw up in my mouth.:sick:
  16. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    I likely would have covered the external vents for the few days it took. Are they not the ones just below the windshield?
  17. Mendel Leisk
    42,354
    Off topic but notable: where I found tons of pine needles and leaves, was up at the top of the front wheel wells, when pulling out the plastic liner for a look. Right at the top towards the back, kinda close to the hood hinges. There's an extra layer of plate welded in there, creating a little box for reinforcement. It's got some drip holes at the corners, but they're too small for all the flotsam that collects. I've got an attachment for my garage wet/dry with various sizes of vinyl tubing that helps to reach in there. Suck what you can, then blow the rest.
  18. bisco
    52,863
    the few days it took for what?
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    for them to receive the replacement filter
  20. Mendel Leisk
    42,354
    I think you'll survive a few days sans cabin filter, lol.
    It's kinda strange: we're well past 50000 km on original cabin filter, a little dusty but still fine.
