Checked my brake pads today...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rebound, Oct 12, 2019.
  1. Mendel Leisk
    42,362
    Disconnecting the 12 volt negative cable is cheap insurance. Reconnect it last thing, and before you do, push the brake pedal multiple times, to take up any excess travel. The disconnect protects against the piston getting pushed out, the pedal pushing when done protects against the car detecting excess travel, throwing a code.
    NutzAboutBolts and Yea Right like this.
  2. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    My 2015 rear caliper pins were rusty at 25k, just a few months ago.
    I lubed them all up good and changed out the rusty rear a week later.
    Check them frequently esp in the rear.
  3. ChapmanF
    19,041
    Were you able to determine how they got rusty? What condition were the rubber boots in?
  4. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    When I ordered new pins I also got spare boots
    However, after a closer look boots where fine and the lube inside was just almost non-existent.
    So i just used the new oring/gaskets in the boot kit
    Not a good pic here but just the rear, i think both were the bottom rear. top may have been a bit better.
    But changed both on each side.
    My C has drums in the rear
    My guess was PA salt and etc.
    Im glad after 5 years I decided to do 100% of my own maintenance.
  5. Joele3
    Joele3 Active Member
    138
    206
    Bay Area
    I thought mine were bad. Thats a whole another level.
    Raytheeagle and dig4dirt like this.
