Checking/maintaining my 12 battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NewHybridOwner, Apr 6, 2022.
  1. CR94
    CR94 Senior Member
    2,786
    1,224
    Northwestern S.C.
    My significantly cheaper ($65) general-purpose AGM just passed 7 years in my Prius, and is still going.
  2. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    Good for you, but statistically, we have more problems with aftermarket AGM than Yuasa (Truestart) battery.
  3. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I bought a new Toyota 12V battery (June 2022 manufacture date) yesterday with 10% off -- so $208.xx (plus tax). When I called, they told me the advertised "10% off parts" was supposed to be only in conjunction with work performed by the dealer, but they gave me the discount anyway. This was at Kool Toyota on the NE side of Grand Rapids.
    ASRDogman and bisco like this.
    52,641
    that's a great deal!(y)
  5. NewHybridOwner
    607
    283
    W. Michigan
    I bought a new OEM battery with a 10% discount, then treated myself to a CTEK 4.3A charger -- a Prime Day special. I've hooked the positive lead to the terminal in the fuse box, but the only way I could find to bring the lead out of the fuse box was to have it pinched between the edges of the box and the cover. Did you find a better way to bring the positive lead out?
  6. Mendel Leisk
    42,119
    I cut off the red plastic shoulder of that positive lead; then you can bend it down much closer to the connection, get it to fit.
  7. NewHybridOwner
    607
    283
    W. Michigan
    Did you manage to get the wire with its connecting eyelet up alongside the thick white wire and then connect it along with that thick wire?
  8. Mendel Leisk
    42,119
  9. NewHybridOwner
    607
    283
    W. Michigan
  10. Mendel Leisk
    42,119
    Did you get the cover off that connection ok? I did it again just this afternoon and man, it never gets easier: two fussy tabs you’ve got to work on, back and forth while prying up.
  11. NewHybridOwner
    607
    283
    W. Michigan
    Yes, I got the cover off, but it took a little while. I hope it will be faster next time.
  12. NewHybridOwner
    607
    283
    W. Michigan
    Is there a 12v battery self-test mode on a 2015 Prius 4? The YouTube videos say to press the "info" button, but mine has no such button.
  13. johnHRP
    646
    189
    KA, DE
    Excel
    Turn the headlight on and off slowly 3x, it will show the menu. In ACC mode it should read above 11.5 V. With headlights ON for 1 minute, if it stay above 11V under this load, it still has plenty of life. If it is below 11V, it is time to shop around. Below 10V, it is completely dead.
  14. Mendel Leisk
    42,119
    Electronic battery testers are cool, around $50~80. I'm using a Solar BA5; it's current iteration is BA9 I think.
