Checking water level in battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ernie1, Dec 24, 2011.
  1. ernie1
    ernie1 Junior Member
    67
    Sacto,Ca.
    After trying to check the water level in my auxiliary battery and not getting a clear view of any place to add water, I decided it was time to remove the battery so I could get a better understanding of how this was to be done. I went through the whole process of dismantling all the brackets, clamps and wires that were in the way, removed the battery and, to my surprise, read the warning on the top that said "Never add water" and "Do not attempt to remove cover". Oh well, I'm supposing this is an agm battery and I'm going to let "sleeping dogs lie".
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Batteries have been maintenance free for a very very very long time now... Where have you been?!
  3. PrimeRisk
    PrimeRisk New Member
    somewhere
    Maintenance resistant is more like it. You can peel off the top sticker on the GS battery and you can add distilled water to it. It's not what the manufacturer intended, but the stock Gen 2 battery is famous for its early death.
    To answer the OP's question, the original GS battery in the Prius is not an AGM, it's a flooded, maintenance-free lead-acid battery.
  4. ernie1
    67
    Sacto,Ca.
    2K1 Toaster:
    Are you saying batteries in general for all applications of vehicles? I can assure you that is not true. Also, I read a previous post where the person said he removed his battery from a 2007 Prius and the cells were low on water and refilled them. Where have you been?
  5. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    FWIW, both the OEM batteries in my 02 Nissan Maxima and 04 350Z required you to add water, if low.
    Even the '11 Nissan Leaf's manual (on page 8-12) refers to adding fluid but I'm not clear if all of them ship w/ones w/removable vent caps and the ability to add water, as pictured in the manual. My Nissan Leaf Forum • View topic - Nissan Engineering Team Visit Dec. 3rd: Recap in the lower pic sure looks like it has removable caps, just like in the manual.
  6. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Right. If the water level is low, the battery will die and they'll get to sell you a new one.
    It's not clear how high the level should be, but it would certainly be safe to add enough to bring them all up to the highest one. Maybe you'll get an extra year out of the battery by keeping the plates wet.
  7. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Hi Ernie,
    It may have been my post you saw.
    Yes, the label says never to add water, but as someone mentioned, it's more of an attempt to sell more batteries and to prevent liability issues. As long as you keep the battery upright and don't overfill it, it's pretty tough to get acid on yourself though.
    Remove the intimidating warning label and place it upside down to reduce its intimidation factor (and keep the adhesive clean).
    Then you'll see a transparent plastic strip covering the 6 cell fill caps. Carefully pry out the plastic strip with a flat-bladed screw driver or putty knife and set it aside. Then remove the small rubber caps but be careful not to lose them--they like to fly/roll.
    The holes are pretty small, but with a flashlight, you should be able to see the whitish-colored plates inside. They were not submerged in the electrolyte when I had my battery out. Add enough distilled water to each cell to cover the plates inside (about 1/4" above the plates--don't fill the cells all the way!).
    Then put the rubber cell plugs back on, press the clear strip back into place and replace the warning label. Put the battery on a slow, smart charger for a while if you can.
    Adding water has really helped my original battery. I put it on a 1-amp smart charger for about 36 hours after I added water. Then the car sat for a week and then booted just fine the next time I drove it. No red-triangle light like I used to see. I think I can keep using the original battery a good while longer.
    I used to leave "maintenance free" batteries alone and just replace them, but once you start pulling vent plugs, you never go back! I added water to the "maintenance free" deep cycle battery in the pop-up camper as well.
    Eric
    2 people like this.
  8. ernie1
    67
    Sacto,Ca.
    Eric:
    Again, thanks for the very clear and timely advice and I'll go at the battery again right after Christmas is over. One thing I found out is that if you have a vehicle with keyless entry and/or gps, the stock battery has a higher amp hour rating than those not equipped with these options. Of course the water level should still be tended to.
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi Eric. Is it easy enough to check the water in the battery while it's in the car, do you have to remove it first?
  10. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    uart--you can try it without removing it but I think it would be easier in the long run to remove it. You have to look practically straight down into the vent holes to see the water level and with the battery out, you don't need to worry about spilling water in the car interior. I would predict a sore back and neck from leaning over the trunk and trying to access and see into the vent holes.
    2 people like this.
  11. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Agree with Tanglefoot in all respects. I think the Engineers at Toyota decided that the 12V Bat would be the sacrificial lamb when it comes to conserving voltage from the main bat. It seems to be current limiting. I have never been able to charge the OEM battery to 14 Volts, either on the car or on the bench. Possibly if left on charger for months it may go up there. I think the term Flooded AGM may be more accurate. Anyway both car and battery are somewhat deficient when it comes to 12 Volts. I recommend a separate charge every 6 months
  12. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    You would think so. But not in Porsches! I had an 03 Boxster where you had to add water to the battery, and the dealer replacement was the same. I said screw that, and bought a maintenance free replacement at
    one of the chain stores.
  13. richard schumacher
    7,682
    1,062
    United States
    Only if it turns into a capacitor :_> 14V is within the range of charging voltages for a lead-acid battery. If you measure 14V on a lead-acid battery that is not being charged there's something wrong with the measurement.
  14. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
