Checklist for 5k service
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NiHaoMike, Jul 14, 2012.
  1. NiHaoMike
    NiHaoMike Member
    98
    16
    Since I have read about dealers performing the 5k services incorrectly, how about let's make a checklist to check for the most common mistakes?
    Here's what I have:
    * Make sure the oil is the correct type (0W-20) and not overfilled.
    * Make sure the oil change panel is latched securely.
    * Make sure the wheel covers are reinstalled tightly.
    52,878
    perfect. and mark the tires to be sure they rotate correctly.
  3. Mendel Leisk
    42,361
    If you have your tire pressures over spec., ask them to leave them alone, and verify after the service, while you're still there.
