Checks After Coolant Flush
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lilly58, Oct 16, 2025.
  1. Lilly58
    Lilly58 Junior Member
    Minneapolis
    Hello all,
    Today, I went to get an oil change, and the mechanic said the coolant was at -15, but they like -35; and recommended a coolant flush (~30 minutes). Nearly two hours later, they had completed the flush stating that there were bubbles, and took a long time before they could get heat flowing again.
    I'm very leary of this dealer's mechanics; they tend to miss the little things when 'buttoning' up after maintenance. So, I'm wondering if there are things that I should keep an eye out for.
    First, the time estimate was way off, so can't help wondering if they ran into difficulties that they don't want to talk about.
    Second, a coolant flush was performed in 2020 @27K miles (now at 36K miles; yeah, I know, exceedingly low mileage on this car as mentioned in other posts).
    Third, read lots of scary stuff about problems with coolant flush on older cars.
    So, here are my questions. Should I be concerned? Are there things that I can check to ensure that they haven't caused more harm than good? Should I take the car to another mechanic to check things out -- if so, what should be checked?
    Any help would be appreciated. Maybe I'm overreacting, but I've decided to keep the car now, and would hate to have something serious go wrong when I could prevent it.
  2. Mendel Leisk
    41,926
    For gen 2 prius, after the initial changes, a coolant change every 50k miles or 5 years (whichever comes first) is what Toyota USA recommends. There's no mention of numbers (presumably freeze protection in degrees Fahrenheit) such as your mechanics, it's just miles/months, change it.
    Gen 2 Repair Manual Repair Manual info, and my spreadsheet summary of Toyota USA's maintenance schedule (which you can also find in the toyota usa publication Warranty and Maintenance Booklet*), is attached below, in excel and pdf formats. Note: I've extrapolated the official schedule to 240k miles or 24 years.
    * The Warranty and Maintenance Booklet, Owner's Manual, etecetera, can be downloaded in pdf format, from Toyota Tech Info website, under the Manuals tab.
    That said, if you look through the engine coolant change instruction from the Repair Manual, there's mention of esoteric device connected via the obd port, which I suspect your mechanic does not have access to. At this juncture, I'd have a dealership service department check it over.
    #2 Mendel Leisk, Oct 16, 2025
  3. BiomedO1
    BiomedO1 Senior Member
    4,171
    2,185
    SacTown, Ca
    First off, the coolant system doesn't need to be flushed. Them telling you that the glycol concentration is wrong; -15 vs -35; all you need to do is adjust the concentration. The proper test to see if coolant replacement is required is a litmus test; to make sure the coolant PH hasn't move toward the acidic side. That would cause deterioration of your plastic and rubber parts the coolant would come into contact with.
    A simple drain and fill is all that's required, per the OEM service manual. Your not going to get all the coolant out doing this, but your also less likely to screw up the coolant concentrations. The concentrations don't move on their own, unless someone is adding distilled water to top off the cooling system. I'm talking about quarts of water, not a few ounces.
    I would probably take the car to another shop with more careful and honest mechanics.
    Just my two cents..........
  4. pasadena_commut
    pasadena_commut Senior Member
    2,865
    858
    Southern California
    Low pH will increase corrosion of the metal too. I wouldn't expect it to hurt the sorts of plastics used in cars much, but rubber, sure.
    For the OP, it might be necessary to add more coolant later if there is air in the system. Park the car somewhere flat each night. Place a Sharpie mark exactly halfway up the side of the overflow tank, in a location you can see easily looking over the passenger side fender when the hood is up. Each morning, when the car has fully cooled off, open the hood and examine the fill level in the overflow tank. If there is air in the system it will push it into that tank and when it cools off will suck in coolant. This assumes that there is coolant up to the neck of the radiator. Check that once (only after the car is completely cool) just in case they woefully under filled the radiator. Anyway, while there is air the level will fall in the overflow tank each day. When it falls below the mark open the overflow tank, put in a funnel, and fill back to the Sharpie mark. In a couple of days the level should stay constant and you are done. Also, good idea to run the heat for 5 minutes or so each day in order to help get any air out of the heater core.
  5. Lilly58
    Minneapolis
    pasadena_commut: Thanks for the advice about the tank fill level. I'll definitely keep an eye out. Noticed that Toyota web page also mentions listening for gurgles on startup which can indicate improper fill.
    Mendel Leisk: Thanks for the info. I guess that 2020 to 2025 is the 5 year mark; so replacement recommendation wasn't out of line. Since this was service at a dealership, I'm not sure that taking it to another dealer or back to the same dealer is going to get me anywhere. However, I appreciate the breakdown by months/years on the maintenance. It gives me a couple of things that I can take the car to another mechanic to have checked, and the work done by the dealer can be checked alongside; i.e. no additional money spent to doublecheck the dealer's service. Also, gives me a good fill-in for what's been serviced and not serviced over the 20 years of this vehicle. I'll take the time to fill it in and keep it on schedule now that I've decided to keep the car.
    #5 Lilly58, Oct 16, 2025
  6. Tombukt2
    Tombukt2 Senior Member
    13,463
    2,420
    Durham NC
    Just open after it cools down once you get in for the day there's not coolant standing in the filler neck you'll be pouring cooling into the tune of about close quart probably . Once you get it full everytime cap off water standing at top of neck ..
  7. Mendel Leisk
    41,926
    I was doing both coolant circuits on ours yesterday (coming up on 5 year interval),, armed with Repair Manual excerpts, @NutzAboutBolts videos. The one thing kinda lacking from my Repair Manual excerpts on coolant changes is getting the car in "maintenance mode", or "inspection mode". The Repair Manual calls it the latter IIRC, and going to that section in Repair Manual you find multiple iterations. Very confusing. This is the bees-knees mode, for use in conjunction with engine coolant change, basically needed after the engine coolant change to keep the engine running steady:
    How to Engage "Maintenance Mode" on the G3 Prius | PriusChat
    Note carefully the mentions of when to press the brake pedal. While not strictly necessary to shift from Neutral to Park, if you don't press the brake pedal, it doesn't go into the "mode". Ditto for setting parking brake at the outset, I believe it must be done.
    At the "end" of the procedure, I figured I'd warmed it completely, shut down, and crawled back under to start reinstalling the undershield. Thought to to feel the two large coolant hoses running to the radiator, and they were still stone-cold. So back into maintenance mode, and just lay under there, periodically checking the hoses. Eventually the thermostat opened, one of the hoses warmed right up, and then the other. Done. :)
    Inverter coolant on the other hand, is quite easy.
    These videos are very helpful:
    The only exception I took, with the engine coolant change, it's best to just fill the reservoir to the "B" line (near very top of reservoir), and cap it, before running the car in Maintenance Mode to warm up. This is the Repair Manual method.
    in the video they leave the cap off the reservoir, and top up. This is traditional, but not needed.
    #7 Mendel Leisk, Oct 17, 2025
  8. Lilly58
    Minneapolis
    Mendel Leisk: Unfortunately, those videos are for Gen3 Prius. While similar, there are some major differences. I just realized that you have Gen3, so the maintenance may not be the same either. But, still, you've got me on the track of keeping a spreadsheet set up with the maintenance. I'll just have to be sure that I get the Gen2.
  9. Mendel Leisk
    41,926
    Oh heck, I forgot. Yeah I believe gen 2 was more trouble prone, in particular for DIY or independent mechanics.
  10. Lilly58
    Minneapolis
    pasadena_commut: There already appears to be a mark on the overflow tank. I'll be checking tomorrow morning. I had a dumb question regarding your remark about running the heater for 5 minutes or so. Prior to the coolant 'flush', I always had some heat if the vents were open to outside air and the engine was warm. Now, there doesn't appear to be heat except when the engine is cold and I turn on the fan. Once the engine is warm, I can't seem to get any heat. I tried setting the Temp to 70 (outside temp was 54 with windows open), and pushed AUTO only to see the AC turned on. So, dumb question, how is one supposed to turn the heat on?
  11. Mendel Leisk
    41,926
    Something weird there. Blockage, stuck shut thermostat?
  12. Lilly58
    Minneapolis
    Just wanted to wrap up this thread. I took the car to another mechanic. By this time, there was distinct gurgling sounds and intermittent heat problems. The mechanic indicated that they topped off the radiator and used a vacuum tool to bleed the engine coolant system. Yeah, I know, technically a vacuum or power flush shouldn't be used, but it looks like there are some pros and cons when it comes to the engine coolant system (not the inverter, which is hands down 'never flush or vacuum'). The heat seems to be working now without issue; comes up usually in about 5-10 minutes after starting, and stays steady. I've checked for any indications of leaks; nothing so far. So, fingers crossed, the problem is resolved.
    Again, thanks to everyone for your help and advice.
    Brian1954 likes this.
  13. BiomedO1
    4,171
    2,185
    SacTown, Ca
    The second mechanic probably followed procedures and properly bleed the system; whereas the first didn't. That's why you weren't getting any heat. As I stated in thread #3. If I was paying someone $100+/hour; I expect them to know what they are doing and do it correctly!
    https://www.automotivetechinfo.com/wp-content/uploads/2020/09/Mastering-the-Toyota-Gen-2-Prius-Engine-Cooling-System.pdf
    Sorry for the rant in advance.
    Lilly58 likes this.
  14. Lilly58
    Minneapolis
    Hey there BiomedO1. Thanks so much for the PDF. That is one great document and explains the vacuum fill tool. I feel better now about the second mechanic and will use him to bring all of the remaining 20 year checks up to snuff. Thanks much for that.
    BiomedO1 likes this.
