Featured Chevrolet Equinox Diesel
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Aug 18, 2017.
  1. bwilson4web
    16,537
    Source: Chevrolet's 2018 Equinox Diesel boasts segment-topping fuel economy
    Chevrolet has revealed its 2018 Equinox will be offered with three engine options, including a new 1.6-liter diesel. That diesel option will have a cruising range of up to 577 mi (928 km) per tank and be EPA rated at up to 39 mpg (6 L/100km) on the highway, which GM boasts will top the compact SUV segment – even when compared to gasoline-electric hybrids such as the Toyota RAV4 Hybrid (30 mpg) or the Nissan Rogue Hybrid (35 mpg)..
    As a general rule, when only highway mileage is mentioned, someone is trying to hide a truth: Compare Side-by-Side
    model City Highway Combined
    1 2018 Equinox Diesel 28 39 32
    2 2017 RAV4 Hybrid 34 30 32
    So it comes down to whether one drives mostly on the highway or urban driving.
  2. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    It's 32 city for the Equinox diesel FWD. 31 city, 37 highway for the AWD model.
    Also, knock about 13% off of all diesel MPG numbers for MPG gasoline greenhouse gas equivalent...
    Data Daedalus likes this.
  3. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    I thought about diesel, but the additional cost per gal. for fuel, it would would need to get 10%-15% mpg better to break-even on fuel costs alone.
    Then there is always the "stink and maintance factor"
    #3 bat4255, Aug 18, 2017
    pilotgrrl and Data Daedalus like this.
  4. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    I can't find if the diesel version is even rated to tow. All I see is the 2.0T gas motor is rated for 3500 lbs. What good is a diesel SUV if you can't tow anything?
  5. wxman
    wxman Active Member
    636
    231
    Tennessee
    That's true, but if you recall our discussions on TDIClub several years ago, EPA uses a "correction factor" which includes "ethanol in fuel" ("Final Technical Support Document - Fuel Economy Labeling of Motor Vehicle Revisions to Improve Calculation of Fuel Economy Estimates." December 2006, page 3). To the best of my knowledge, EPA still uses this correction factor for all vehicles (non-EV) including diesels. Of course, diesel fuel doesn't contain ethanol, so that artificially suppresses the fuel mileage ratings of diesels and why (I think) diesel tend to exceed their official fuel mileage ratings.
    bhtooefr likes this.
  6. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Interesting, although the implication from that document is that only about 1.2% of downward adjustment is coming from fuel composition - the rest of the 9.5% downward adjustment is coming from the load side, rather than the fuel side, and would affect diesels as well.
    That's definitely something to be considered by the EPA in their adjustment factors, and an argument for removing the fuel composition adjustment from diesels. (Although, you'll have a smaller fuel composition adjustment necessary for states with B20 mandates...)
  7. wxman
    wxman Active Member
    636
    231
    Tennessee
    True. Maybe it would be more accurate to say "one of the reasons" diesels tend to exceed their official fuel mileage ratings.
    According to an article in "Green Car Reports" (EPA gas-mileage labels accurate, helpful, unlike 2005: Consumer Reports), a Consumer Reports analysis showed that LD diesel vehicles exceed their official fuel mileage ratings by an average of 0.7 mpg. Not sure what percentage that is, but it looks like it's more than 1.2%.
  8. Trollbait
    12,831
    By the EPA's own research from 2008, diesels can get up to 10% better than their label.
    Will also add that the diesel Equinox has start/stop standard, and those systems have little impact on the EPA tests.
    #8 Trollbait, Aug 18, 2017
    wxman likes this.
  9. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    I wonder if that research still holds true for compliant diesels today.
    Note that all of the diesels they had available to them in 2008, with any significant data, were old diesels that had high NOx output (legally, mind you). I wonder if there's something in the measuring approach that biased high-NOx engines' fuel economy figures down?
  10. bwilson4web
    16,537
    Back in the day, I did some analysis of Jetta diesel metrics reported by users to the EPA. It appeared the EPA metrics were low compared to Jetta reported mileage but the Prius was spot on with no significant overlap. The Jetta users were claiming Prius-like performance then 6-7 years later, we found out about the VW cheat.
    BTW, I've added an updated table from www.fueleconomy.gov:
    year model trim City Highway Combined %
    1 2017 RAV4 Hybrid AWD 2.5L 34 30 32 33.3%
    2 2018 Equinox Diesel AWD 1.6L 28 38 32 33.3%
    3 2018 Equinox Diesel FWD 1.6L 28 39 32 33.3%
    4 2018 Equinox Gas FWD 1.5L 26 32 28 16.7%
    5 2018 Equinox Gas AWD 1.5L 24 30 26 8.3%
    6 2018 Equinox Gas FWD 2.0L 22 29 25 4.2%
    7 2018 Equinox Gas AWD 2.0L 22 28 24 0%
    Good luck!
  11. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    I stand corrected, and looks like that article was wrong on the city mileage in the place I was looking in it.
    bwilson4web likes this.
  12. bwilson4web
    16,537
    As long as it wasn't Consumer Reports. <grins>
    pilotgrrl likes this.
  13. Trollbait
    12,831
    Well, if they are honest diesels, any negative effects to fuel efficiency from the emission system should be equal on the test and on the road. Then DPFs started showing up before 2008, so the effects of their regen cycles could be in that data.
  14. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Actually, another factor I just thought of... how many of the pre-cheating diesels were actually compliant?
    A lot of TDI enthusiasts (the kind of people that will submit their data to fueleconomy.gov) install modifications that increase the emissions profile significantly, but also improve efficiency (advancing injection timing and removing the EGR being the two big ones for improving efficiency). So, those mods won't show up in the data, but their effects will.
    However, there's another possible explanation for diesels doing better in the real world - extremely light load isn't very well covered in the test (see idle stop systems also not helping much on the test), and extremely high load isn't seen at all. Diesels are better than straight gasoline engines in both regimes - wide open throttle at all times reduces pumping losses for light loads, and no need (or ability) to enrich the mixture to cool the intake charge and avoid detonation helps significantly at very high loads. That could account for some real-world improvement (and calls for the test to be modified to include those operating regimes, I'd say).
    #14 bhtooefr, Aug 22, 2017
    pilotgrrl and Trollbait like this.
  15. Trollbait
    12,831
    A fair consideration, but also one for the gasoline cars that get reported. While most gas cars that are purposely non-compliant are likely for performance reasons, and not self reported for fuel economy, there are still the ecomodders out there. What does the Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com do to the spread?
    Selection bias is the downside to user reported data like this.
    Another factor is in the 55:45 city:highway split used for combined mpg. That average reported by those users was around 43:57. This is also close to the default ratio the EPA uses in their MOVES model.
  16. hill
    9,039
    Diesel . . . NOX . . . EquiNOX. it makes sense.
    :p
    pilotgrrl, telmo744 and Trollbait like this.
  17. Trollbait
    12,831
    If only Toyota could fix the HSD towing issue.;) The Rav4 hybrid's rating is half that of the Equinox diesel.
    For fun, I personalized the numbers at Fueleconomy.gov with these hopefully temporary prices, and the Rav4h might cost me 10 cents more to go 25 miles than the Equinox. Before the the storm, the Rav4h could be 20 to 30 cents cheaper. Back to default city/highway mix, and random Costco prices in California has the Nox 8 cents cheaper.
    #17 Trollbait, Sep 6, 2017
  18. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    It's cooling that affects that, and the P610 appears to be improved (to the point that, in some markets, even the Prius gets a tow rating), we'll see if the P710 gets a better tow-rating in the next-gen RAV4.
    And, there's always going to a multi-stage approach, like the L310 as used in the LC 500h and LS 600h. It'd be tougher to package, but maybe you could get a 2-speed reduction box in there reasonably, and through that, get better towing performance.
  19. Trollbait
    12,831
    Or use an actual gear oil in the transaxle instead of the automatic transmission fluid that was sitting on the shelf.
    Even with cooling, the gen4 Prius tow rating is lower than cars a size class smaller than it in those markets. Toyota could just be overly cautious though. Either way, I don't expect the next Rav4h to double its tow rating. In truth, that really isn't needed for the segment.
    But, but, what about the mechanical simplicity that is the end all be all?
    I think Toyota wouldn't try this because of costs, but I say that not knowing customer towing needs in other markets.
  20. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    In the US, towing doesn't matter much, because people think they need an F-150 to tow.
    In Europe, people will tow with anything - they'll tow big campers (granted, they're lightweight, but they're big) with a subcompact that can't do 30 mph up a hill with the trailer.
