Chevrolet Volt tops Sierra Club ranking of plug-in hybrids
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by a_gray_prius, Jun 25, 2013.
  1. John H
    John H Senior Member
    2,208
    558
    Of course I charged the Volt first. What is your point ?
  2. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Fair enough.
    I wonder why PiP sales seem kinda low. Haven't followed things.
  3. mikefocke
    3,999
    1,807
    Sanford, NC
    Volt next-gen news in Motor Trend. Main take away was GM intent to get cost down by $7-10k to drive volume.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    They will likely drop the big bonus cash and dealer incentives ($4000-$8600) as well which will allow them to lose less on each sale yet retain volume.
  5. Trollbait
    12,543
    I've heard speculation that it might seat 5 with the same EV range. A 4 seater might also be offered with a 50 mile EV range.
    If they manage $7000 off, that will get into the PPI price range.
    Wasn't the PPI supposed to go national in June?
  6. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Avoiding the same OPUD trap (again) doesn't seem to be a strong point. o_O
    Originally, yes. Toyota responded to the market fallout (other plug-ins) by choosing to focus on existing availability location instead, delaying full rollout until the next model year.
  7. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
  8. john1701a
    12,818
    5,303
    58
    A quick check of 1st generation inventory makes that a strong possibility...
    The end of May, unsold new inventory available was about 9,100. As of this moment, it's shown to be 8,245. Based on those numbers, it looks like even just matching May's sales of 1,600 will be a problem. Despite the $4,000 price-drop, sales didn't increase. In fact, they did the opposite.
    GM's decision to build what they wanted to sell rather than what was needed is clearly backfiring. Sure, the system itself is winning awards, but what the heck is the point of that? GM consumers are still buying their traditional vehicles instead. Mission not accomplished.
    GM has a long-running "over promise, under deliver" reputation. How do they avoid falling into that same trap again? With so much pressure to overcome the shortcomings of this generation, telling people they will and false hope leading to unsupported hype like it did last time is very easy.
    Being realistic about expectations doesn't attract headlines. Dealing with lots of unsold inventory makes a bad situation even worse. What's going to happen?
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Umm John. I see many more Prius owners selling off their cars for Volts. I have yet to see it go the other way.
    Trollbait and austingreen like this.
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    You must be a fool to think I don't understand.
    I think we both agree that it was badly written. The two sentences I quoted sums it up. There was a lack of understanding for MPGe.
    You and I can comprehend better with prior knowledge and discussions but for you to say it is 101 as a normal Joe should be able to, is totally incorrect.
    It appears you are referring to PiP. Let me correct you. 95 MPGe rating is from a blend of gas and electricity. To be specific, 18.9% gas and 81.1% electric. If Volt is driven with the same fuel ratio, it would be rated 74 MPGe.
    95 MPGe > 74 MPGe
    You need the efficiency of both electric miles (EV) and gas miles (HV). The ratio of each fuel matters only if one is bias toward one of the fuel.
    The fuel usage ratio depends on driving speed, range and charging pattern. The owner will pick the most suitable plugin that best match his/her commute range. Range comes with trade-off due to the limitation of Lithium battery. Generally, the more EV range, the less efficient, lower interior space and longer charge time. The cost increases too but the tax credit lessen the blow.
    For my PiP, I am averaging 132 MPGe on electric miles and 54 MPG on gas. Leaf's City cycle efficiency on electric and Prius gas efficiency on highway. This is typical for a lot of PiP owners, so I am not the exception. The best of both worlds.
    3PriusMike and Merkey like this.
  11. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Find me one Model S owner selling it to get a Volt. :)
    Electric mile attracts some. Total efficiency attracts others. Practicality, affordability or the total package (regular Prius) is what most goes for.
  12. john1701a
    12,818
    5,303
    58
    Conquest sales don't address the reality that GM customers are not stepping up to Volt. They replace their GM traditional car with another GM traditional car.
  13. austingreen
    austingreen Senior Member
    13,675
    4,213
    Austin, TX, USA
    Hey if you want to play the fool, go ahead. I figure I would give you the benefit of the doubt. I don't think its misleading at all, you simply are trying to be too clever and misinterpret it. There I have said it. Use your brain, and don't think the public is so stupid as you perceive.
    I was giving you something better than the epa claims for the prius phv, and inflation of efficiency if you prefer. If the volt is driven 29 miles from a full charge why would it use any gas? Aren't you trying to handicap it here to do as poorly as the prius does, because it must use gas at higher speeds. This is not an engineering problem for cars with higher battery power. I expect that toyota will fix this in the next version. You have to imagine a trip both cars are on, not pretend they have the same limitations. I am sure you would claim a 500 mile trip to hit the volts limitation. If you do many of these, say twice a week you will do better in a prius phv, but again this is what, less than a percent of the population that will not buy a plug in anyway. YMMV.
    Sure but you did the math wrong.
    Yes and this is the bias of the sierra club and myself. It is even the bias of the DOE. We would rather import less oil.
    I don't think the 208 mile range of the tesla S kills the efficiency, its the same as the prius phv. There are other factors. This is a problem if you are trying to sell low range cars, you will use gas.
    Well good for you, but you didn't give us a total. What percent of your miles are gas? Would you use less oil if you had a longer AER?
    Trollbait likes this.
  14. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Astingreen, Model S 60 kWh is rated 95 MPGe. 85 kWh model is rated 89 MPGe.
    Using EPA is fine to compare but the MPGe it rated is for one driving range and assumes one charge per day. Everybody has different driving range and charging pattern. Plugin's MPGe swings widely depending on those variables.
    This is why we should look at the bottom line. I.e: efficiency of both fuels broken down by the miles they were driven with. Pretty simple concept. It is not about bloating numbers.
    My lifetime fuel ratio is 47% electric and 53% gas. The last 6 months is 51% electric and 49% gas. How about yours?
    Using less oil is one of the goal. Not increasing refueling time is another. Not giving up 50 MPG on regular gas is another. Not giving up a flat cargo floor or a rear seat is another. There are many others and I am not all electric range (AER) love blind.
    BTW, why is my math wrong?
  15. Merkey
    Merkey Active Member
    315
    285
    Birmingham, Michigan
    F8L, also just noticed you got your Volt. Hope you like it. I see lots of them in the Metro Detroit area, but it is GM HQ.
    F8L likes this.
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That won't happen because the Model S has the range AND it is nice to drive. :p
    I specifically said Prii owners. They seem to be the ones trading in for Volts.
    drinnovation and Merkey like this.
  17. Jeff N
    Jeff N The answer is 0042
    2,382
    1,304
    California, USA
    2011 Chevy Volt
    That guy and the other Volt reviewer at TTAC that he refers to are credibility-challenged and are spreading BS. TTAC is strongly biased against GM and the Volt.
    See this earlier thread where I point out the implausibility of those claims:
    Prius vs Volt: 55 miles & 3,000' Elevation 4 days a week: | PriusChat
    F8L, cycledrum and bwilson4web like this.
  18. bwilson4web
    16,217
    Huh?
    Congratulations on your new experiment but you might consider updating your profile. At least now some things make a lot of sense, a familiar pattern.
    Plug-in Prius owners? Do you have some numbers?
    The reason I ask is we know Ford's improved hybrids also had some 'conquest' sales of Prius owners. But that only makes sense when one looks at the specs of the Ford hybrids which are more Camry hybrid class. A comfortable, American style ride, the expanded market is going to appeal to Prius owners who value creature comforts and vehicle acceleration and driving experience over mileage.
    Three years ago, there were only a couple of fuel efficient cars. The Prius came in any style you wanted as long as it was a hatchback or the 2001-03 compact. The fuel efficient market has expanded so it only makes sense that those who used to have no options to choose something else. Based upon these sales numbers, I'm not ready to run-around, set my hair on fire, and jump off a building:
    Column 1
    0 [tr][th]model[th]May_13[th]Apr_13[th]Mar_13[th]Feb_13
    1 [tr][td2]Toyota Prius Liftback[td2]15330[td2]12432[td2]13868[td2]11428
    2 [tr][td2]-[td2]-[td2]-[td2]-[td2]-
    3 [tr][td2]Toyota Camry Hybrid[td2]4265[td2]3257[td2]4461[td2]4147
    4 [tr][td2]Toyota Prius C[td2]3782[td2]3486[td2]4026[td2]3148
    5 [tr][td2]Jetta Diesel[td2]3752[td2]3158[td2]3653[td2]3261
    6 [tr][td2]Toyota Prius V[td2]3732[td2]3372[td2]3460[td2]2543
    7 [tr][td2]Fusion Hybrid[td2]3335[td2]3625[td2]3417[td2]3806
    8 [tr][td2]Ford C-Max Hybrid[td2]3261[td2]3197[td2]3275[td2]2849
    9 [tr][td2]Passat Diesel[td2]2797[td2]2797[td2]3237[td2]2233
    10 [tr][td2]-[td2]-[td2]-[td2]-[td2]-
    11 [tr][td2]Nissan Leaf[td2]2138[td2]1937[td2]2236[td2]653
    12 [tr][td2]Tesla Model S*[td2]2000[td2]2100[td2]1950[td2]1400
    13 [tr][td2]-[td2]-[td2]-[td2]-[td2]-
    14 [tr][td2]Sonata[td2]1817[td2]1447[td2]1623[td2]1441
    15 [tr][td2]Malibu Hybrid[td2]1695[td2]1551[td2]1359[td2]1254
    16 [tr][td2]Lexus CT200h[td2]1623[td2]1171[td2]1062[td2]1182
    17 [tr][td2]Chevrolet Volt[td2]1607[td2]1306[td2]1478[td2]1626
    18 [tr][td2]Avalon Hybrid[td2]1514[td2]1423[td2]1616[td2]1361
    19 [tr][td2]ES Hybrid[td2]1434[td2]1237[td2]1561[td2]1154
    20 [tr][td2]Kia Optima Hybrid[td2]1206[td2]1000[td2]1001[td2]1215
    21 [tr][td2]-[td2]-[td2]-[td2]-[td2]-
    22 [tr][td2]RX 400 / 450 h[td2]885[td2]688[td2]925[td2]756
    23 [tr][td2]MKZ[td2]715[td2]884[td2]446[td2]177
    24 [tr][td2]Prius Plug In[td2]678[td2]599[td2]786[td2]693
    source: hybridcars.com dashboard report
    Now if the Volt is leading to "Prius Plug In" trade-ins that would be news. I would be interested in the source of that metric.
    Given the Prius has been sold since 2001-current, I would be surprised if a few Prius owners didn't buy a non-Prius, fuel efficient car . . . including the Volt. They also buy Fords, Hondas, and other fuel efficient cars that did not exist when the Prius was first bought.
    GOOD LUCK!
  19. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    The point is: Prius has consumed exclusively gasoline.
    You had to put energy in Volt that has been lost later on in ineffiencies of its ICE.
  20. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Bob,
    The ones I have heard from or read about were GenII and GenIII owners. I don't know of any PIP owners crazy enough to trade so early besides myself. Now had I rented a Volt and PIP to test on my commute I would have chosen the Volt first. Sometimes I need to listen to my own advice. :)
    bwilson4web likes this.
