Chevron Techron Concentrate Plus Fuel System Cleaner
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by paphillyman, Dec 8, 2018.
  1. Rocky Mountain Priusman
    Rocky Mountain Priusman Active Member
    224
    112
    Canmore, Alberta, Canada
    Here is a good video showing results of Techron on cylinder head cleaning. Looked like it did some minor cleaning but nothing impressive.
    His channel actually tests a variety of cleaners. Looks like Seafoam and Royal Purple yield better results than others.
    This doesnt speak to cleaning other parts of the fuel system like the injectors:
    #21 Rocky Mountain Priusman, Apr 10, 2021
  2. AW82
    AW82 Member
    188
    99
    Madison, WI
    I'm currently (slowly) running 44k as preventative since my mileage is better than expected already.
    As far as what's in it...I stuck my finger in and it sure didn't feel like Ethel.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Considering that Techron makes NO claims that it will do that, those results are not surprising at all.
  4. Rocky Mountain Priusman
    224
    112
    Went to Canadian Tire today. The "Formula One" fuel injector cleaner wasnt there, but they had a simular product from the same brand called "Fuel Saver". The "Fuel Saver" claims to clean injectors and intake valves. I figured it probably cant hurt (fingers crossed) so I bought it. It sais one 0.475 litre bottle treats 500 litres of gasoline so obviously you dont need much.
    Of course they had all the other brands of fuel injector cleaners and other cleaners. I figure the only way to be sure you bought the right brand is to rotate through a bottle of each different one over the years :D
    https://www.canadiantire.ca/en/pdp/f1-gas-fuel-saver-475-ml-0388049p.html
  5. Rocky Mountain Priusman
    224
    112
  6. Rocky Mountain Priusman
    224
    112
    Good point!
  7. Mendel Leisk
    42,352
    FWIW I didn’t notice anything, using the Formula 1. Wasn’t expecting to, and were low kms, injectors pretty clean to begin with.
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    I find it rather odd that Techron isn't available in Canada.
    Look for Berrymans B12 Chemtool.
    It is a good "heavy duty" fuel system cleaner.
  9. Mendel Leisk
    42,352
    Yeah. I think it used to be, too. Mighta read something, chevron didn’t want the hassle of metrifying the bottle?? Not sure.
  10. Krall
    Krall Member
    125
    37
    NY
    I've used that and a few other ones and then I found Royal Purple. It's like adding a turbo charger to my Prius, I can almost feel the rear wheels doing a burn out :D
  11. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Of course in the USA we can go TopTierGas.com stations and get a good dose of detergents. My area is almost all TopTier so I do not worry about detergents. In the golden oldy days (pre ~Year 2000 or so), before EPA mandated US gasoline recipes, typically the better cleaning additives would be found in Premium grades, and Premium was marketed as such. In other countries, that may still be the case, not sure.
  12. sam spade 2
    7,035
    2,804
    2017 Prius c
    If by "good dose" you really mean the mandated minimum quantity, then that is right.
    The consumer has absolutely, positively NO WAY to know for sure if any gas that comes out of the pump has any detergents over the mandated minimum or not.
    In fact, you don't really know if even the minimum is really in there.
    But I think it is a fair assumption that the major players are following the rules about formulations.
    "There are 3 kinds of lies: lies, damn lies and marketing."
    (Modified slightly from the original.)
  13. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Are you blowing out your exhaust pipe?
    moto g power ?
    Krall and scona like this.
  14. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    A bit late to this discussion, but Top Tier gasoline claims to have significantly more than the mandated minimum quantity. The big names, e.g., Shell, BP, Mobil, Marathon (and others I don't see around these parts), plus Costco (but not Sam's Club), plus Meijer (Midwest supermarket chain).
  15. Krall
    Krall Member
    125
    37
    NY
    It's so good Wheaties were blasting out my exhaust pipe :)
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    Claims are not facts. Especially marketing claims.
    UNLESS you live in an area where the gas stations get their product DIRECTLY from a "top tier" refinery, you don't know what is or isn't in the gas that they do get.
    Gasoline is mostly a "commodity product" these days. That is, it is all the same in most places because it all comes out of the same pipeline into the remote depot where the trucks fill up.
    So.....in that case, you are depending upon the depot operator, truck driver or station owner to actually put in the additives that really make it "Top Tier". YOU might trust that that happens correctly 100% of the time but my guess is MUCH lower than that.
  17. ToyXW
    ToyXW Active Member
    153
    149
    Sacramento
    According to a AAA study:
    BMW, General Motors, Fiat Chrysler Automobiles, Ford, Acura/Honda, Toyota, Volkswagen, Mercedes-Benz, Navistar, and Audi all recommend using Top Tier gasoline.
    I don't think any independent/third party tests fuel from stations to ensure it meets top tier standards (like various agencies do to ensure you get at least 95% of every gallon the pump says it puts into your tank). But I can tell you that my local oil distributor has different tanks for different stations and the Indian Casino, a TA truck stop, & a consortium of mom & pop stations all draw from a separate tank than top tier Arco, Costco, & Valero. Truck drivers from this facility do not put additives in, nor do gas station owners. I presume the distributor does or it comes off the train with additives already in it.
    Chevron, 76, & Shell don't get gas from the local distributor so I can't speak to their procedures. I do know my aunt owned a station that used to be independent, but became a Chevron affiliate and now Chevron manages the fuel 100% - right down to which credit cards are accepted at the pump.
